Printing problems why after printing a task does printing a second time not occur. I have continuous problems printing after the first task
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Sounds like a driver issue, try deleting and reloading driver, if same try a different version of driver.
Posted on Mar 27, 2014
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Touch screen keeps freezing
Does the screen also freeze if you are using a mouse instead of touching the screen? If the freezing still occurs, then the problem is NOT the touchscreen. If it works OK with the mouse then you may need to have the touchscreen repaired. If freezing occurs even with the mouse the cause may be one of several. Right-click on the Windows taskbar and select Task Manager. The task Manager box tells you if your processor is working very hard (any reading that continues to hover near 100% indicates some program or process is overworking your system. Task Manager also shows a list of processes and how much cpu % each process is using. Another possibility is that to run everything you want may require more RAM memory. In general, 4GB or RAM is enough, but if you're running a lot of programs/apps at the same time then you may wish to boost your total amount of RAM to 8GB or more.
Sep 25, 2014 | Lenovo IdeaPad Computers & Internet
My Compaq Presario computer does something very strange. Every day, several times a day when I am online computer light turns amber and it starts screeching. I can not continue using Internet when it...
Sounds like it is overheating. Pull the side panel off of it, clean the fan blades and vents. 3am may be the time that it looks for updates.
You may also want to download a free version of Super antispyware as well as malawarebytes, just to make sure you are not infected. These two programs together will remove problems that other virus software will miss!
Jan 14, 2013 | Alienware PC Systems Computers & Internet
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
Problem with printing - streaks yellow and green not all colours are printing, not used for some time but new cartridges have been put in
Follow these steps to print a nozzle check:
  1. Turn off the Stylus CX.
  2. Load letter-size paper in the sheet feeder.
  3. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds.
    The Stylus CX turns on and prints a test pattern, which includes anozzle check. Shown below are some examples of what the nozzle checkmay look like.
If any of the colors is missing, perform a head cleaning routine. It appears that the magenta head is having some problem. Try printing again after performing a head cleaning task. If the problem continues you might need to replace the head.
Thank you.
Oct 11, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Display message won't stop: Press Enter to align cartridges.
I honestly don't know how I solved it; I did everything your forum suggests at least two times (restarting, disconnecting, re-installing, etc), but nothing would work. After I got up the next morning (four hours sleep!), I did it all again, and this time it worked. I did two things differently that may have worked. Somewhere in the owners manual, it says to wait for quite a long time (like over 5 minutes--I don't have the manual with me now). Also, it says to NOT turn the printer on until AFTER installing the software. Those two little items may have made the difference, but the main idea of reinstalling came from you. Thanks!
Jun 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
T420 error lights
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
Oct 16, 2007 | Lexmark T420d Laser Printer
44 people viewed this question
jasbo
jasbo
