Question about Motorola Cell Phones
Display run automaticly
Display run automatically i can;t fix it
  • Official Brand Answer
  • 3,100 Answers
All the time or only when plugged in?
Mark
Motorola Support
Posted on Jan 31, 2015
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
Tip
Checking for Windows updates results in an error message (0x8024001D)
When running Windows Update, Express or Custom, displays an error message (0x8024001D) saying "The page can not be displayed" error occurs.
The resolve is to rename the SoftwareDistribution folder:
Stop the automatics Updates Service
Go to Start>Run and type in Services.msc
Click OK or press Enter
In the right pane of the services window, right-click on Automatic Updates and then select Stop.
Navigate to C:Windows (C:WINNT if using Windows 2000) folder, locate and rename the SoftwareDistribution folder to SDOLD
Restart the Automatic Updates Service by re-opening the Service window, Right-Click on Automatic Updates and then select Start
NOTE: Renaming the SoftwareDistrbution Folder removes your current update history listing.
Reference: http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windowsupdate&tid=b5f7cbb5-4307-42a1-b3dd-8b259937525e&9=1
on Mar 24, 2010 | Computers & Internet
My 2004 buick rainer is stuck in park but dash board says its in drive how can i fix this
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid
The automatic transmission shift lock control switch
Can you or can you not take it out of park ?
Shift Lever Does Not Move with Brake Pedal Depressed
yes or no ?
PRND321 Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the gear position. The PRND321 display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the ECM.
You have a transmission range sensor or PCM problem , Need a professional grade scan tool to diagnose the problem , well that would be the easiest way to test .You should have all modules test for DTC'S - diagnostic trouble codes ! That would point you in the right direction ! I would suggest you google class 2 serial data communication network !
Aug 17, 2015 | Buick Cars & Trucks
How do i fix nokia E63-1 display light automatic glow after some time?
Your set need to be casing keypad require clean-up
Dec 15, 2013 | Cell Phones
Displays "E1" and resetting the
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR24VC3 24,000 24000 BTU Air...
My problem is only sound driver of my hp pavilion dv5215us Entartainment Notebook Pc. IT HAS NO SOUND
Method 1: Use the Windows XP Sound Troubleshooter How to fix it automatically
To fix this problem automatically, click the Fix It button, and then click the Run Now button. Then, follow the steps in the FixIt wizard.
a.button { background: url("/library/images/support/KBGraphics/PUBLIC/cn/FixItButton.jpg") no-repeat scroll 0pt 0pt transparent; width: 139px; height: 56px; display: block; cursor: pointer; }a.button:hover { background-position: right bottom; } Fix this problem
Microsoft Automated Troubleshooting Services: Diagnose and fix sound playback issues
Note This wizard may be in English only. However, the automatic fix works for all language versions of Windows.
Dec 31, 2010 | HP Pavilion dv5215 Notebook
I hv a garmin nuvi 200w which shuts down automatically
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 29, 2009 | Garmin nuvi 200W GPS Receiver
Help!!!!!!
Did you reset your settings on the PS3 to display in 1080 whatever while you were there? If so, you may have go back over and change the display setting to "automatic" (or automatically detect...I don't remember exactly what it says off the top of my head). There may be an easier fix but I can't test it for you because all of my tv's are HD. For future reference, "automatic" or "automatically detect" is always the best way to go with settings. It avoids situations like this. :^ )
Good luck.
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
The display is going of when switch on
If u want the display to stay on at all time u have to acces ur menu. Under settings or tools. Look for the display sub-menu and enter what u want.
Jun 20, 2009 | LG KG300 Cellular Phone
What is "OPC"? It comes up and goes away.
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cell Phones Logo
13 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
