Question about Diesel DZ4083 Watch for Men
I am looking for a wrist band for diesel watch model DZ4083
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
  • 14 Answers
SOURCE: watch band for shark freestyle model 788
You can call 718-7298600 X272 , ask for Linda order the band, it will cost you $12.00
Thanks
Tsai
Posted on Dec 08, 2007
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
Suunto X9 replacement band
looking for a replacement wrist band for my watch
May 23, 2012 | Suunto X9 SS004729320 Wrist Watch
Ia am looking to bay a watch wrist band
mcdevito75 here, Ebay is your best bet. They have a large selection of wrist bands for all watches. Or, you can visit a small watch repair shop in your area for a new band.
Aug 19, 2010 | Casio Sea Pathfinder SPF70-2V Wrist Watch
Looking for a replacement wrist band
mcdevito75 here, Ebay is a great choice for almost any new watch band, or, you can look for a small watch repair shop in your area for this new band.
Aug 10, 2010 | Nike Triax 0027 Wrist Watch
I want a new strap for Diesel dz4083 from were i can get.
If you need help with product information, ordering assistance, or returns information you can contact us via one of these three options:
Diesel Time Frames Customer Service
2280 N. Greenville Ave.
Richardson, TX 75082
TEL: 800-699-2556
customerservice@dieseltimeframes.com
Alternatively, touch your toes together 3-times and repeat softly: "There's no watch like Diesel Time Frames, There's no watch like Diesel Time Frames, there's no watch like Diesel Time Frames" and you will be transported to our customer service center in Kansas. Or maybe Texas. Or maybe not. If this fails, try one of the other 3 methods of contacting us listed below.
You've got a choice. You can contact us by telephone at 800-699-2556 between the hours of 8:00am - 6:00pm CST, Monday through Friday. Or you can email us at customerservice@dieseltimeframes.com. We aim to respond to your email within 24 hours, excluding weekends, or during the office fishing trip the third week of June.
Jul 23, 2010 | Diesel DZ4083 Watch for Men
I just bought a diesel watch from ebay model no DZ7068 and for some reason the wrist band doesn't tighten.. i got confused is there any solution for this? thanks chris
mcdevito75 here, Without seeing the watch NO. Best Bet, visit a small watch repair shop in your area and see about band adjustment, Most likely your missing something on the band you have to use to adjust for your wrist size.
Jun 28, 2010 | Watches
Watch band for shark freestyle model 788
You can call 888-222-5230 x502 Customer service. The band was $12 plus $3 shipping.
They will need your watch model. Shark Mako 788 (01)
Web site is www.freestyleusa.com
This is through Geneva Watch Group NY
Other post lists old extension (Linda works in another department now).
Oct 21, 2006 | Freestyle Shark Mako 788 Wrist Watch
Diesel DZ4083 Watch for Men Logo
177 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
randymanfive
Are you a Diesel Watch Expert? Answer questions, earn points and help others
