Question about Tablets & eReaders
Screen says unfortunately launcher has stopped after reset used
CAN NOT GET ANYTHING ON THE SCREEN BESIDES UNFORTUNATELY LAUNCHER HAS STOPPED
The launcher has stopped
go to launcher, stop it and clear data and cache. Exit the settings menu and restart.
http://forums.androidcentral.com/asus-memo-pad-hd7/357082-unfortunately-launcher-has-stopped.html
Jul 07, 2016 | Tablets & eReaders
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
You need to do a FULL reset.
1. Power off unit
2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
3. Scroll down to factory reset and select it.
4. Agree to reset
Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
Good luck
May 25, 2015 | Ematic 7" Touch Screen Tablet
Can't use my tablet. Getting error: the process android.process.acore has stopped. Is there anything I can do?
Unfortunately, I purchased the same tablet and found it to be junk as well. I returned it and was sent an M9200...just as bad, so they refunded my money and I still have the terribly, slow tablet. Try resetting the tablet by uncovering the tiny hole to reset it covered by a small sticker on the back of the tablet.
Oct 20, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Why do my tablet says unfortunately vLauncher has stopped and I can get it off the screen
You must uninstall the launcher, if you can't do this, them you must to factory reset the tablet.
Aug 29, 2014 | Tablets & eReaders
My nook hd says "unfortunately, Home has stopped
You can use alternates to the Home app that defaults on Nooks.
The Home app and the alternatives are all what are called Launchers. You can make your Nook look and feel just like any other tablet you have ever seen. I\'ve personally been using one for years called ADW.Launcher on both my Nooks and just love it. The Nooks default default Home launcher is just a bloody pain to setup.
You can still use both launchers side by side. After running ADW.Launcher for a while you will just ask how you ever got around without it and never want to see Home again.
Jul 07, 2014 | Nook HD+
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Mar 17, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Android launcher stopped unexpectedly
Disconnect the battery for 10 minutes. Then try again. Are you doing the 3 finger hard reset?
Dec 04, 2013 | Sylvania Synet7lp Mini Tablet 1. ghz Arm...
My daughter's new Childpad is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to reconnect to wireless router but no joy. What can I do?
Look. It happened to me and drove me crazy. I was about to brick my new mobile phone. In my case it was the "Moon call log" icon on the home screen. Believe it or not when I remove the icon the error message no more appears when I restart the mobile phone. Then again when I place it (the icon on home screen) the annoying error message "Unfortunately, Launcher has stopped" will comeback again. In your case it could be any icon or widget.
I solved the problem by uninstalling the application and installing it back from Play Store unlike what I did before by installing it from the .apk file.
Regards,
Oct 28, 2012 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
Tablets & eReaders Logo
13 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
