Question about Dell Wireless Keyboard Optical Mouse w0147
Keyboard Unresponsive at Boot, Keyboard/Mouse Randomly Fail
My keyboard started being unresponsive at boot-up after I had to repair it using a passkey supplied by the computer after the batteries died.
Before this instance, I have been dealing with both the keyboard and mouse intermittemntly becoming unresponsive for minutes at a time before working again for a year now. It acts like a background task is pre-empting console input.
Dell suggested I update to the latest drivers for my mouse/keyboard and latest BIOS for my XPS 420... No joy.
    Master:
  • Dell Master
  • 126 Answers
Posted on Jun 03, 2017
5 Suggested Answers
SOURCE: Inspiron 1525 Touchpad has a mind of its own
I have had the same problem.  This may sound strange, but try the following:
Switch off the notebook.
Remove the battery and keep the on off switch pressed for >5 seconds.
Replace the battery and start the computer again.
The problem should then be resolved.
Posted on Apr 29, 2009
QueFixYa
  • 44 Answers
SOURCE: kennsington 72214 mouse is unresponsive in XP Pro
Hello friend,
You must either reconnect your mouse or just install the hardware again all together because some how either your signals are being crossed or blocked.
Posted on Mar 06, 2010
Firetree
  • 179 Answers
SOURCE: Have a Dell Dimension. rebooted
First, I would try booting to Safe Mode and see if that gets you to Windows. If it does, then it's a driver issue that can be relatively easily fixed by "Uninstalling" the keyboard in the Control Panel/Device Manager, then rebooting and letting the system reinstall the driver.
If that doesn't do it, then it sounds like the (assuming you're using a PS2 keyboard) PS2 keyboard plug port may be compromised (ie., damaged). Try using a USB keyboard instead and see if that solves your issue (as trying to repair a PS2 keyboard port is not practical).
Hope that's helpful.
Posted on Dec 31, 2010
Ezrahite
  • 2632 Answers
SOURCE: I have a Dell XPS
Welcome to Fixya. If you have isssue with the bluetooth connection of your Keyboard and Mouse then all you need to do is to use the guide provided below to fix the issue. You also need to make sure that the driver for your bluetooth device is already install on the system
Dell XPS 420 Drivers
Resolve Bluetooth mouse or keyboard failure to function - Microsoft (Refer on Method 4)
Mouse, Keyboard or Touchpad Not Working Correctly - Dell (Refer on Issue 2)
Hopefully the problem will be fixed.
Thanks for using Fixya.
Posted on Feb 27, 2011
Floppy disk fail (40) CMOS Checksum Error Defaults Loaded & Keyboard Unresponsive
Unplug the floppy drive cable from the motherboard and test.
Problem still there??
Check the leads of the 3 integrated circuits starting with the one directly to the right of the LAN connectors, and working down and to the left to the other integrated circuits.
The problem you are looking for is two leads shorted together or a lead broken by somebody who was careless with a card, and hit the IC during assembly.
There can also be a short caused by trash or loose components, but that is not as common.
Oct 06, 2015 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Unresponsive keyboard
Does this apply to all of the keys? Does the mouse still work?
I want to establish if your computer is unresponsive or just the keyboard
Mar 14, 2015 | Computers & Internet
Compaq nc 6220 laptop keyboard water damaged and all keys unresponsive
We have all done it .It was a cup of tea that went over my last laptop and there was no way that I could repair it. If you have insurance cover on it specifically you may be able to claim, otherwise expensive repair.
Keyboards start around 19 pounds free postage on Amazon There are wireless ones too. Hope this helps Anna
Mar 02, 2013 | HP Compaq nc6220 Notebook
Keyboard unresponsive only 5's on screen
Sounds like your keyboard has been hijacked by a virus. Try booting into safe mode and see if the keyboard acts the same way. Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal. If it is ok in safe mode then run your virus scan.
Mar 29, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Acer aspire 5100-3583 boots, screen is on, but
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 07, 2017 | Acer Aspire 5100-5033 Notebook
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
I have an Hp Pavillion a1547c and when I boot up the keyboard is unresponsive. I can use esc to get into the boot menu and f1 to enter setup but once those screens load the keyboard is no longer...
Go into the Bios utility and enable all the USB controllers, then save the changes, exit the bios. The computer will restart, plug the keyboard into another USB port and let the computer boot up, wait about 5 minutes before trying to use the keyboard because the drivers maybe trying to install themselves.
If you get no luck you will need a standard PS/2 keyboard, connect that and boot your machine, log into your account and install the drivers for the USB keyboard.
Good luck.
Jul 01, 2009 | HP D8597A Keyboard
Keyboard won't repond during the boot process
The motherboard is clearly perfectly fine, if it tries to start up windows, are you using a USB keyboard? if so try the old Style PS/2 oval or round shaped connector type keyboard and see if that works.
Let me know how that goes so can continue to diagnose the problem.
Nov 07, 2008 | Computers & Internet
Unresponsive keyboard/mouse
sounds like the wire is loose or not hooked up right. mite go back inside and see if your mouse and key board is wire is hooked up .
Apr 17, 2008 | Acer Aspire 5100 Notebook
Keyboard problem I think, Hope! compaq pressario R4000
Try using an external keyboard and see if that works.
Nov 13, 2007 | Computers & Internet
Dell Wireless Keyboard Optical Mouse w0147 Logo
115 people viewed this question
Alun Cox
