Question about Comdial 8324S-PT Corded Phone
Have the condial 7260-00 and need to change the main line greeting
Need to change the greeting
How do I change the main greeting on MLS-12D program?
This is what I have:
Intercom 777
99#
password 1234#
9
* # (to by-pass selector code changes)
press 1 to record a new greeting, when done, press 1
* # to save changes
Jan 08, 2015 | AT&T Lucent MLS-12D Phone
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
Jul 17, 2014 | Comdial Dx-80 7260-00 Digital Executive...
I am trying to change our main voicemail. It only gives me the option to change the extension voicemails, not to change the main greeting that comes on when no one picks up the phone to the main line??...
If you log into mailbox 998, which you can from anywhere in the World, you can get access to all of the greetings. You just have to figure out where they are stored. This is assuming you have a Panasonic brand external voice mail.
Carl
Apr 23, 2011 | Panasonic KX-T7731 Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
May 18, 2009 | Nortel Business Series Terminal T7208 -...
Change voice message on nortel meridian phone system
You need to go in to voice mail admin .
Feature 983 1020000
press AA
press Greeting
press greeting again
enter 1 for greeting 1
this should be your main greeting it could any greeting from 1- 20 , it depends on how it was set up but that should work fine .
Feb 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Need to change greeting
main system greetings can be changed via the administrator mailbox, dial your voicemail huntgroup number, on answer press the * key and supply the admin mailbox number which is usually 999 or 9999 the default pincode is 8642 then follow the voice prompts to change the system greeting.
Jan 30, 2009 | Mitel 5220 IP Phone
Voice Mail Greeting
Get into admin section of voicemail. Select change greeting. Select greeting number (probably 001). Rerecord. Need help. Email. If this is helpful, please post as such
Jan 27, 2009 | Vodavi Starplus SP7314-08 Corded Phone
I can't change the main greeting for our office line..
Unfortunately, Office systems are all controlled by a central system that requires an administrator to make changes such as recording the system answer menu, creating menu systems, etc. This is usually done by the I.T. department or private contractor. Sounds like maybe you have a gap in personnel. If that's the case, you'll need to call Nortel for support. Thanks for using Fixya!
Jan 27, 2009 | NorStar T7316E Corded Phone
Changing main greeting
You need to go into Feature 983 system admin. You need to get the password though.
Dec 18, 2008 | NorStar Meridian M7310 Phone
Comdial 8324S-PT Corded Phone Logo
32 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
