Question about Alpine HDD Navigation VIE-X08
Alpine HDD Navigation VIE-X08 why cant read disk, disc slide inside...panel close...but nothing come out...is it i reset need what setting again?
Really cant be solve this japanese alpine
tech48
  • 624 Answers
SOURCE: Alpine CDA 7878R - Hi Temp - won't play disc
Does it play the tuner but not the CD?
If it so, the problem is directly related to the CD deck. If not, the problem could be a sensor or any number of other components that may have overheated.
Try to reset the unit. Most of the time this error is an electrical problem not fixable by the end user. But it is worth trying to reset the microprocessor and see if that helps.
Here is a diagram of where the reset button is at. Press it in with the tip of an ink pen or paperclick, whatever you have that will fit into the little hole. Just hold it in a couple of seconds. Be advised that when yo reset the unit, you will loose all things in memory like the correct time, preset radio stations ect.
If this does not help you will need to have it checked out by a good repair center. These Alpine radios are very good radios and are worth getting fixed unless the estimate is close to what you paid for it.
good luck, I hope this helps. if so, a good rating would really be appreciated. You can always ask me for more help if you need it. I have been repairing car and home audio equipment for over 17 years.
Posted on Jun 21, 2008
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Posted on Aug 20, 2008
  • 28 Answers
SOURCE: alpine equalizer wont work
to have them work you have to connect the yellow wire to constant 12 volt power,and the red to blue and white wire coming from the radio if you dont have a blue remote wire on the radio connect it to the accessory of the car wire that power the radio
Posted on Dec 04, 2008
  • 4970 Answers
SOURCE: need to reset alpine 7510T
If this is the model fitted in a TOYOTA then the code is only available from the Main Dealer or a Decode Specialist (or your local Car Radio / Audio Store) who will connect a laptop to read/recode the memory chip
Posted on Sep 21, 2009
Testimonial: "thanks we had no idea what or where to go so that is great "
How do I set the clock/language on an Alpine VIE-X08MS in car media station & navigation unit in a 2010 Japanese Mazda Axela I-stop
Hi Brendan, Hit menu, then Navi set up, then Cailbration, then clock set. There you can change the hour only, the system will only set the minutes automaticly.
Also - make sure you're NavData is set to the region you are in. I had to do that when I first got mine. You'll see a map of the USA and you can change the predetermined regions. I do not recall off the top of my head how to get to that screen. I am NOT sure if that has ANYTHING to do with the clock & time zones.
Nov 24, 2017 | Alpine Car Audio & Video
Language Problem
Try Googling (alpine)(VIE-X05)(manual) without parens.
Apr 01, 2014 | Alpine 7-inch Double-DIN GPS Navigation...
Alpine SD navigation system VIE-X05 update loading file free download
ALPINE VIE-X05 SD NAVIGATION SOFTWARE file need. my sd card is dad's plzz solution for me.
Jan 04, 2014 | Alpine 7-inch Double-DIN GPS Navigation...
How can i change the language?
if your system have English language then you able to chance otherwise software update in only option
May 19, 2012 | Alpine HDD Navigation VIE-X08
My navagation system keeps saying that it "cannot read disk" please check disk. Do i need a new disk or is something wrong with my system? 2006 Jeep Grand Cherokee?
the the problem is from the laser (lens) of your navigation system. It cannot read disk because the laser (lens) is weak or dirty.
Its might also be that the disk you inserted into the system has some scratches or the disc is bad. Try several discs on the system.
If problem still persists after trying several discs, get the laser replaced and it should read disk again.
Good luck.
Nov 08, 2010 | Cherokee Jeep Grand RB4 Navigation, AM/FM,...
Cant read a folder in a hdd transcend storejet 2.5 110gb
Looks like you probably have some corruption on that disk. Assuming it isn't physical damage on the disc, running a CHKDSK on that entire drive may fix that for you.
With the drive plugged in, open My Computer, right-click on the drive and select PROPERTIES. Then click on the TOOLS tab, click CHECK NOW, check both boxes then click START. Let than run and it will tell you when it is done. Once it is, try opening that folder again.
Jan 21, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
2005 honda pilot with navigation, i purchased this unit from the usa and imported it to canada. navigation system doesn't work, where is the navigation disk slot located and is there a disk for north...
same problem, disc is located under passenger seat, talked to honda canada , alpine and honda usa, they dont make a disc for 05, couldnt get nav in 05 cannadian pilots , they dont even make north america disc just stricly usa maps
Jan 19, 2009 | 2005 Honda Pilot
Nvd v002 alpine navigation
I have the same problem and its been hapening since February. Thought that it was earthquake as I live in Lincs and son said it might be lazer but have finally rung aloine and they say its a satellite problem to do with US putting up more sats and the software can't read it. They are sending me out a free disc to sort it out but need to follow instructions implicitly. Hope this is solution to your problems Ring alpine number is 08703 333761
Mar 06, 2008 | Alpine NVDV002
Alpine HDD Navigation VIE-X08 Logo
82 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
