Question about Campbell Hausfeld 28 - Gallon Air Compressor
Wont start motor wines over then trips breaker
    Problem Solver:
  • 6 Answers
You have a air pressure switch on the compressor. When your tank gets to a certain pressure it will shut down until the pressure drops below a certain pressure. More than likely you have a bad pressure switch, the contacts are probably stuck in the closed position which would explain why your tripping the circuit breakers. You should be able to go to the Campbell Hausfeld site to identify and order the switch. This is something you can change out yourself, it is a simple R&R
Posted on Dec 10, 2009
  • Alan Jacob Apr 08, 2010
    The pressure relief valve is something different. That will relieve the pressure in the tank if it builds up to high. (it could rupture the tank) If that valve is bad, your compressor will run all the time, (because the valve is dumping all the pressure) or you will rupture your tank because of too much air pressure. (thus, the air pressure relief valve)
Mine is doing the same thing. I was told that I needed to check the pressure relief valve, but I don't know where it is located.
Posted on Jun 16, 2009
My dryer will not start
If you hear the motor then the belt is broken If you have the control panel working it is no guarantee that the breaker didn't trip Find the breaker in your breaker panel and reset it.
Nov 29, 2013 | Speed Queen Dryers
98 civic overheated,then now will not start ,turn the key and just wines ,wont turn over
Try turning the motor over by hand, with a
socket & long breaker bar or ratchet, on the
crank damper bolt
You may have a broken timing belt & the valves
are jambed against the pistons,from what your
saying the motor is frozen & the starter won't turn it
Aug 26, 2013 | 1996 Honda Accord
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Bissell lift off bagless tripped breaker. Cut
if it overheated, there is a automatic switch in or near the motor that resets automatically...if its cooled and wont start back up??? Then check that your outlet has power to it. if not, reset trhe house breaker and if it does, start hitting garage sales for 5 dollar vacuums....
May 02, 2010 | Bissell 3750R Air Conditioner
Washer starts to spin up then trips breaker
Good day,
Not the transmission. The motor could be stalled by a defective transmission, but the motor would trip off on it's own internal long before the home breaker.
Sounds like a short in the motor itself. But ......
There is Murphy's law.
Your home breaker might have become so weak, it IS the problem.
You really need an amp probe to check the washers draw, at the circuit breaker panel.
If you cannot do that and are comfortable dealing with electrical, you can swap equal value breakers, to be sure.
Jan 03, 2010 | Washing Machines
Dryer wont start, timer clicks but wont start
the thermal fuse is open its the white plastic looking item on the blower housing
Sep 10, 2009 | Dryers
GE DVLR223 dryer wont start....breaker is not tripped
check all the connections on the back of the dryer, if a few screws are loose, that could be the problem.....now the other thing....it might need a new motor. Unplug it before checking it out!!
Clean out your vent hose and the outside of the Vent to prevent fires.
Jul 31, 2009 | GE DVLR223 Dryers
Cooler keeps on triggers breaker
If it is tripping the breaker, stop plugging it in. The breaker is tripping because something is wrong, and continually resetting the circuit WILL cause a fire. Either return the unit, or have an electrician look at it. You can also try plugging it into another circuit in your house to isolate the problem, but please don't repeatedly reset the breaker, there IS a problem somewhere.
May 27, 2009 | VinoTemp (VT60GNV) Wine Cooler
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
360 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
