Question about Brookstone MAX 2 Dual Node Percussion Massager
My Max dual massager stopped working - runs but no movement to heads - can it be repaired?
Massage heads stopped moving, although the motor sounds like its running inside. It suddenly stopped working as if something had snapped inside. Can it be repaired? If so, how to go about this?
Superba 8524570
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | KitchenAid Dishwashers
My preeti lavender stopped workng suddenly
If its new, I would return it for warranty.
Dec 31, 2012 | KitchenAid ProLine 600 Stand Mixer
Ford Fiesta 1.2LX Zetec Engine model 1999...Passenger Side Electric Window suddenly stopped working, although the Driver's Side still works...could anybody tell me if they know what is wrong with
either window button or motor gone is ther any noises at all from the door cards like a thumping noise or is it dead all together but sounds like motor to me as a fuse would knock both sides off
Aug 17, 2012 | Ford Fiesta Cars & Trucks
I went recently to shop around for a massage chair. The salesman went on and on about all the benefits it would bring me. What they don't tell you are the disadvantages I can expect from buying
There are a few disadvantages to note. First being cost. Paying to use a massage chair can quickly add up. Secondly, you should consider weight. Massage chairs are generally very heavy. This can be a huge disadvantage is you need to either move the chair or are having it shipped. Lastly, you should consider effectiveness. Although the use of a massage chair can be very relaxing and beneficial for aches and pains, they are not as effective as a professional masseuse.
Aug 06, 2012 | Furniture
What is the difference between a Swedish massage chair and a Shiatsu massage chair?
A Swedish massage chair incorporates five different stroke patterns (sliding, kneading, tapping, vibration and friction) across muscles groups; while a Shiatsu massage chair combines pressing, swaying, patting and rolling movements while targeting pressure points.
I have a Brookstone dual node massager model # BST-007 SKU# 324640 E 201637. (2001) It is old but hasn't been used much and the other day it quit working. The Brookstone Store told me that they do...
I don't have a solution, but I have the same unit, and it works sometimes, if I keep hitting the start button. The lights flicker more and more like it will start and eventually it does. I use it on my practice, so a fix would be welcome.
Sep 01, 2011 | Health & Beauty
Which heads to use for what
The Manual says the heads are color coded:
Black = Soft Massage
Medium Grey = Medium Hard Massage
Light Grey = Hard Massage
Red = Heat Massage
Jun 13, 2011 | Homedics Pa 100h Percussion Massager With
If the heads are off, the motor runs. whenyou snap the heads back on, the motor stops
Sounds like one of the heads are damaged or something is not put together correctly causing it to jam. Watch the video below to make sure that you have the heads in correctly.
http://www.shaveroutlet.com/philips_norelco_heads_replacement
If you have everything in correctly and it stll jams, one of the heads is likely damaged. You can remove them individually and turn the blade clockwise inside the comb with your fingers. Each should turn freely. If any will not turn, you will need to replace them. You will find replacements for model 8175XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
May 04, 2011 | Philips Norelco 8175XL Electric Shaver
Brookstone MAX 2 Dual Node Percussion Massager Logo
122 people viewed this question
Top Brookstone Health & Beauty Experts
Da Doc
David Ellis Rhea
Are you a Brookstone Health and Beauty Expert? Answer questions, earn points and help others
