Question about Sony ICF-CDK50 Under Counter CD Player/Radio Shelf System
I get very poor reception on fm channels. Is there a way to improve the reception on this power cord antenna set up? I have tried repositioning everything with no luck.
Poor fm reception
4 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Sony CDX FM reception
Yes you need to check your antenna if the tuning has not shifted. there could be an insulation fault if the antenna have a faulty cord within. the present models come with a fixed antennae and so the problem is limited. Look behind the set to see if the jack to the antenna input is loose. You can connect another one to confirm this , if so change with an original replacement as there are many spurious low quality ones. I am sure you will get more years of use. Good day.
Posted on Jul 07, 2010
SOURCE: FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Posted on Jul 18, 2010
caroldon
  • 17130 Answers
SOURCE: str-685 has poor fm reception. have tried 3 different antennas.
If you are sure with the antennae then the fault is with the RF section within, It can be related to a faulty RF section, tuner or IF. You need to take a signal test to confirm.
Posted on Nov 01, 2011
Question about GE Slim Spacemaker 7-5302a CD Shelf System: Where can I find the antenna?
Connected to the variable capacitor. It turns when you turn the tuning knob if one. Image impossible to make out for antenna.
Sep 04, 2017 | GE Audio Players & Recorders
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Dec 25, 2010 | Bose Wave Radio
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
    Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
    Flavio/Brazil
    Jul 13, 2010 | Sony Audio Players & Recorders
    Jan 31, 2010 | Sony ICF-CD513 Clock Radio
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    Dec 29, 2009 | RCA RP5430 Clock Radio
    Sony ICF-CDK50 Under Counter CD Player/Radio Shelf System Logo
    51 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
