Question about Braun Pulsonic Rechargeable Cordless Men's Razor - Silver
Trimmer not retracting back into shaver all the way
I have the same problem happen after about 15 months. The trimmer stays after being closed projecting approx. 1/4" from the face of the shaver and will not retract flush to the body. It also appears to be the spring. Does anyone know if there are there disassembly instructions for this and how it might be fixed? Sending it in for warranty can take up to two weeks. If I send it out for warranty my beard will get out of control and I don't have the hockey playoffs excuse anymore!
This shaver was over $270 canadian. This should not happen so soon.
Hi Sorry I don't have the answer but this must be a common problem as my braun has the trimmer sticking out at 45 degrees when closed. The head lock went 2 weeks before the trimmer wouldn't retract so it looks like a design problem
Posted on Mar 27, 2010
  • just two more Mar 23, 2011
    The problem is caused by debris (whisker remnants). The fix is to flip the trimmer open-close, open-close multiple times under running water (including the space immediately above the power on button, when the trimmer is open).
Side burn trimmer won't stay closed on 790cc braun razor .
Almost certainly, the trimmer is broken and will need replaced. The part and replacement video instructions can be fount at shaveroutlet.com
Braun Pulsonic and Series 7 Shaver Trimmer Assembly
Jan 22, 2017 | Braun Health & Beauty
The trimmer on my Braun 1775 FreeControl shaver has stopped working. When it is engaged, the pitch (sound) of the shaver changes in the usual way with the usual increase in vibration. However the trimmer...
The trimmer is either broken or clogged up with a combination of shavings and skin oil. If it is broken, there are no replacements available. If it is clogged, you can fix it by thoroughly cleaning it. Dip the blades of the trimmer into some rubbing alcohol or other mild solvent type liquid. Soak it for about one minute. Then take an old toothbrush and firmly scrub the teeth. Then turn it on and it should free it up. If it still doesn't move you can advance the blade manually to get it 'unstuck'. One of the blades is fix and the other moves back and forth. You should be able to see which one is supposed to move by sight. Take a small flat screwdriver or similar object and push the blade to each side once. Turn it on and it should move freely. Dip the trimmer blades back in the rubbing alcohol while it is running and let it run for about 15 seconds.
If still not working it is beyond repair. The easiest and least expensive way to get working again would be to purchase a new ;lower unit' which includes the trimmer. You will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-1775-freecontrol-lower-unit-p-828.html
Aug 24, 2011 | Braun FreeControl 1775 Hair Trimmer
Installing the big shaver back into trimmer
Feb 15, 2011 | Conair HCT420CS
I am having problem taking the back off my R-9500 Electric Shaver, I removed 2 screws, one at the bottom & other near button for trimmer. I have pushed the the trimmer button up to open the trimmer,...
The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body.
Sep 29, 2010 | Remington Titanium SmartSystem R-9500...
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Jan 25, 2009 | Braun Activator 8595 Electric Shaver
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Trimmer won't work
There's a post inside the trimmer that provides a location for counterforce when the teeth move; this is either weak, designed to break after time, or breaks simply because it's not designed to be opened/closed while running. It's relatively easy--if you're patient--to take the razor/trimmer apart and see the problem. A friend and I drilled an appropriately-sized hole through the back of the trimmer at the snapped-post location (which, if one looks at the outside casing of the trimmer is at the bottom of the indented arc), used a dremel tool to cut off an appropriately-sized metal rod, inserted it in the hole, then sealed it with hard (probably model) putty. Years later, it still works fine and--most importantly--I didn't have to buy a new razor.
Jul 11, 2008 | Norelco Reflex 5811 XL Electric Shaver
Where do I buy a replacement side-burn trimmer for the shaver?
The trimmer is sold as the back housing assy. I have them in stock. Please call me aty 1-888-643-9806 to order 1. I will tell you how to get the shaver apart to replace. Ask for Action Mike.
Jun 05, 2008 | Braun 8585 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Pulsonic Rechargeable Cordless Men's Razor - Silver Logo
825 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
