Question about Philips 26PF9966 26 in. LCD Television
Philips 23PF9966/37 color problem!
After turning on the TV, the picture is green and in certain settings (sport color mode) red can be seen as well. There appears to be no blue at all. When I unplug and replug the TV, the TV channel and sound indicators in the upper left and right corner of the screen come on blue and white, so all colors seem to be working for a short moment. Then, when the TV picture is displayed, the colors turn back to green and some red, no blue.
Does anybody know what causes this type of behavior?
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Posted on Jun 15, 2009
How to set perfect color on samsung 48" led smart tv
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
Jul 27, 2014 | Televison & Video
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Picture red can not fix
Step 1:
The problem you have is the grayscale tracking needs to be reset.
First, This looks like a philips tv. In order to set the grayscale tracking remove the back of the set. There should be rectangular shaped box that is marked screen and focus on it with 6 knobs coming out of it.
Step 2:
NOTE: DO NOT TOUCH ANYTHING INSIDE THE SET-YOU WITH BE SHOCKED! WITH THE TV TURNED ON, WITH THE REMOTE, TURN DOWN THE COLOR TO ZERO. ON THE CONTROLS I PREVIOUSLY MMENTIONED, THERE ARE RED,GREEN AND BLUE ADJUSTMENT POTS.
Step 3:
TRY TURNING DOWN THE RED UNTIL YOU SEE A NORMAL GRAY PICTURE. YOU MAY HAVE TO ADD MORE GREEN OR BLUE AS NEEDED. IF THIS DOESNT LOOK RIGHT ,TURN ALL 3 R.G ANDB ALL THE WAY DOWN, THEN ADJUST THEM UNTIL THE COLOR IS JUST APPEARING ON THE SCREEN, MAKE THE PICTURE AS GRAY AS POSSIBLE. iF THIS DOESNT WORK,YOU WILL NEED A SERVICE PERSON TO REPAIR YOUR TV.
Jan 20, 2013 | Televison & Video
Need to replace the picture tubes in the tv. all the colors are off. where can i find these
fast check color in tv menu.then collect tv service menual book from market.setting red, green,blue on white picture.
May 30, 2012 | Philips Magnavox 51MP392H Rear Projection...
How do i get my tv back to home mode when it is in retail mode
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Feb 22, 2011 | Philips 42PFL5332D 42 in. LCD Television
Bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Mar 26, 2009 | Philips 51PP9303H Rear Projection...
Try to adjust it in the Service Alignment Mode (SAM).
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Coloration - poor picture
TRY UNPLUGGING SET FOR A FEW MINUTES...PLUG IN LINE CORD WHILE HOLDING PRESSING POWER BUTTON..IF THIS DOES NOT WORK..CPU BOARD IS FAILING...P/N 667-L32K5N-56I...TRY CALLING MCM FOR PARTS AVAIL/PRICE...JOE ACE
Jun 05, 2008 | Insignia IS-LCDTV32 32 in. Television
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Philips 26PF9966 26 in. LCD Television Logo
527 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
