Question about Lenovo Wireless Mouse N3903
I need to pair a lenovo wireless mouse
Don't know how
Can't pair HBS-730 with laptop Lenovo Z510, Windows 8.1 (Headset is at list of devices, but after 1 second (or even less) of pairing loosing connection). How can I fix it?
your computer doesnt have bluetooth,you will need to get a usb bluetooth dongle,like one with a wireless mouse,invest in a wireless mouse and then you will have bluetooth
Apr 06, 2015 | Radio Communications
Cant find nano mouse receiver can i still use mouse without it
You will have to purchase a new receiver. There is no software solution for a lost mouse receiver I am afraid
Sep 11, 2014 | Gear Head Mp2325blk 2.4ghz Wireless...
Lenovo mouse charging
Most of the mouses have a kind of switch and when opened, there are 2 batteries. you can replace them with other rechargeable batteries
May 28, 2012 | Lenovo Wireless Mouse
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I INSTALLED THE DRIVERS FOR KEYBOARD AND MOUSE, KEYBOARD WORKS FINE, CAN'T GET MOUSE TO OPERATE AND DON'T HAVE THE MANUAL HANDY
You may need to "pair" the mouse with the receiver dongle. Look for a button on each. Press button on the dongle first, then on the mouse.
Aug 28, 2011 | Microsoft Multimedia Keyboard/Wireless...
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
I am trying to pair my lg Xenon with my Lenovo laptop. Both devices ask for the passcode.. I don't know the passcode is what should I enter?
For initial pairing, you're the one to provide a passcode. So if the system asks you to enter passcode, you will need to enter a code that you will use as this is the enrollment process. Once the passcode went through, the paired devices will be connected and locked to the system unless deleted or removed manually, so make sure to use a generic passcode that you can easily remember so you won't have any problems in the future. Hope this helps!
May 19, 2010 | Trendware TRENDnet TBW-101UB Bluetooth...
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Mar 08, 2010 | BenQ M310 Wireless Mini Optical Mouse
I have a brand new I-Mac with Snow Leopard. I just bought a Gear Head KBL8000WRBT keyboard and mouse set. I started with the mouse. The computer recognizes it, but won't pair with it.
Since iMacs are not primarily designed to run with equipment like this (They can run it, but the equipment usually says 'No! I don' know what you are!') Try using the apple Magic mouse. (I'm not sure if they have a W/L keyboard.)
Sep 27, 2009 | Gear Head Wireless Bluetooth V 2.0 Desktop...
Problem pairing wireless mouse to reciever
HI ALL, Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is the process of coordinating your mouse's transmitter with your mouse's receiver. It requires both parts to operate on the same frequencies, usually by using the same identification code. Pairing takes place to try to eliminate interference. Some devices automatically pair both devices at start up; others need to be manually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteries in mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) and place the batteries. Cover, Now you can see the red light glowing on the bottom of the mouse, now your mouse is ready to pairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE will be ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, if mouse curser is not moving then press BUTTON 2 one time – now defiantly your mouse will work, If you need any other technical support for GMAX, products please contact
Sep 08, 2007 | BenQ M310 Wireless Mini Optical Mouse
Lenovo Wireless Mouse N3903 Logo
95 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
