Question about Arctic Cat Sabercat 600 EFI LX Winter Sports
Chain case bearing keep losing oil
How to solve problem
    Champion:
    New Friend:
  • 220 Answers
Most modles have an o ring around the lower case berring. Make sure it is still good.
Posted on Sep 29, 2014
What are the steps in replacing the rear seal in a 1966 ford f-100 with a 352 engine?
I wouldn't be surprised if you didn't have to remove the engine/transmission, split the trans from the engine, remove the TC or clutch/pressure plate, (you should have drained engine oil and auto trans oil before doing this), remove the oil pan, remove the rear most main bearing cap, rotate a new seal into place, replace rear main bearing cap, torque, etc. and reassemble.
Worst case you may have to remove harmonic balancer and front timing chain cover, front seal, release all the connecting rod caps and main bearing caps, remove the crankshaft, replace the rear main seal and reassemble. It's a 1966 engine...you should consider replacing the front timing chain with a roller chain as well as rod and main bearing inserts if you have to do all this.
Feb 04, 2017 | Ford Cars & Trucks
How can I grease the bearing?
no greasing is needed , just keep putting oil in for the chain
Mar 28, 2016 | Poulan Pro PP5020AV 50 cc Gas Powered...
How do I switch a crankshaft
Disconnect the battery. Remove the spark plugs. You will need to remove the engine and transmission from the vehicle (unless you have a lift, in which case you only need to remove the transmission.). Separate the engine and transmission. Remove the flex plate (flywheel). Remove the serpentine belt and crankshaft pulley. Remove the timing cover, timing chain, and crankshaft timing gear. Remove the oil pan. You may have to remove the oil pump for clearance. Remove the rod bearing caps. Keep them in proper sequence. Remove the main bearing caps. Keep them in proper sequence. Remove the crankshaft.
You will need new rod and main bearings to replace those already in the vehicle. You will need a new oil pan gasket and timing cover gasket set. Depending upon mileage and age, you may want to replace the timing gears, chain and guides. You must know all proper torque values for the crank and rod bearing caps, flex plate, and timing cover.
As you can well see, this is not a job for the auto DIY novice.
Mar 05, 2015 | 2003 Honda CR-V
1992 gmc Jimmy Losing power, Check engine light on, cutting off, Idling
It looks like that the cause of your leaking pan gasket is excessive blow-by gases pressure due to worn out piston rings. The low oil level is a telltale sign the you are consuming (burning) oil because of this problem.
I recommend that you have a ring and if possible also bearing job to your engine. Merely replacing the torn out gasket will just temporary solve your leak problem. Since you will still burn oil, your emission problem will not be solved.
Oct 13, 2012 | 1992 GMC Jimmy
The chain keeps coming loose
If the chain keeps coming lose it can be down to a number of things, inadiquate oil to the chain, incorrect type of oil in the tank, poor quaility chain, worn sprocket and or guide bar.
May 14, 2012 | Garden
I have a husqvarna 345 with an 18 inch bar and i keep burning the tip up. the oiler is working but its not putting enough oil to the bar. iv checked and found that the oiler is not adjustable and i cant...
At the end of the bar there's a small hole. Every time you fill the oil you should also put some oil into that hole and turn the chain so it spreads into the bearing. The chain oil is not intended to be enough for that bearing. I hope that will solve your problem.
Nov 20, 2010 | Husqvarna Garden
My saw smokes profusely while runing and seems to be getting the oil from my oil reservoir. What could be the problem.
There is no common connection point within the engine itself. A possibility that the plastic lower case which contains the two tanks in a common casting has developed a crack between the two tanks which would seem to indicate fuel in the chain oil as well. Replacement of the plastic casting seems to be the only remedy. Make sure that you are using 50:1 well-mixed fuel to oil ratio. Another unlikely possibility is a very loose crankshaft output bearing/seal assembly that could be drawing chain oil in from the chain area. Check for this by removing the bar and chain, then try moving the center of the clutch assembly in various directions. If perceptible movement is noticed, replacement of the bearing and seal would be desirable. Hope some of this helps!
Sep 13, 2010 | Homelite ZR10926 16 Chain Saw
How do i remove the water pump on a 1999 suzuki rm 250
hi,drop the oil, remove the right hand casing. undo the water pump casing. remove the impeller (10mm bolt) dont lose the copper/ally washer. draw the drive shaft from the inside of the casing. remove the bearing. remove the seals, keep note which way round the seals are. they should be opposite. one keeps oil in and the other keeps the water out of the oil. if there are any score marks on the drive shaft,replace it , as it will only leak again. to put it back together, just reverse process. hope this helps. kev.
Mar 08, 2010 | 2005 Suzuki RM 250
How to lube a case 1840 drive chain, sounds like the chain is binding a bit, it only occours after a few hours of running the machine. will go away once cooled down, need to know how to gain access to the...
There is a drain plug at the back of each chain case, to let old fluid out. Once drained you can refill through the plug on the side between the wheels near the bottom of the case, or remove the 6 bolts that hold the outer bearing on the drive motor, and fill through that larger hole. Each side take 6 liters, and Case recommends their 10w-30 engine oil. In hot climates, 15w-40 engine oil will work.
Jan 07, 2010 | Bruder Cat Skid Steer Loader
During a cold start, I have a noisy rattle coming front the front of the engine on the low down side. This continues for about 10 seconds then quiets down. Any ideas? 1997 Nissan pu, 4 cylinder.
Sounds like a timing chain issue, eventually the tensioner builds enough pressure to quiet it. Also check all chain guides, they get damaged with chain noise like what you describe.
Sep 25, 2009 | 1997 Nissan Pickup
Winter Sports Logo
255 people viewed this question
Top Arctic Cat Winter Sports Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
