Question about Rc2 116 John Deere 125 Lawn Tractor
Need a parts schematic for a 48c mower deck!!
Need to order replacement parts.
2004 gx335 48c mower deck primary pto belt has broken twice new double pulley on rear nothing rubbing no noise
Is the belt overly tight? My mower was doing that to, turned out the belt called for was 1" longer then the belts i was buying for it, making the belt really tight and it kept over heating from rubbing and failing. I would run it for a while then shut everything off and see if the belt is hot, also check that the bearing are not hot, could be friction somewhere causing the belt to heat up and fail.
May 04, 2017 | Garden
I need a diagram on replacing a deck belt on my huskee 21 horse power 46inch cut riding lawn mower model # 13AT688H731
Many of these machines have a belt route schematic on the underside of one of the foot rests
Jul 28, 2012 | Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How to Replace v belt drive
For the YTH2246 only...
1. All you need for this job is a small 1/4" ratchet and a 3/8" socket to install/replace the 1/2" X 106" V-belt [(no. 68 in the mower deck schematic for this tractor) Husqvarna part # 532 40 51-43, Sears part # 33156, Rotary Outdoor Power Equipment Service Parts part # 912106 (12-7549)] ($36-$42)
2. Total time for this DIY job: about 15 minutes.
3. Lower the deck by moving the manual height adjuster to the lowest position (position 1).
4. The only screws you really need to remove are the rear retaining 3/8" hex-head screw of the LH cover mandrel and both from the RH mandrel cover. Just swing the left-side cover out to get access to the LH pulley.
5. Slightly pull from pulleys the legs of the keeper belt mandrel LH/RH to remove/insert the belt. Did I mention you don't need to loosen/remove any screw other than the ones mentioned above?
6. For more assistance, take a look at the schematic in the owner's manual or online at http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602060.pdf
Mar 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Rc2 116 John Deere 125 Lawn Tractor Logo
16 people viewed this question
Top Rc2 Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Rc2 Toy Expert? Answer questions, earn points and help others
