Question about Intel Motherboard
I have a red light color behind the green light color in my board.What did this mean? The board number is DQ965GF
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hi..the indicator lights is meaning the board is found a shorted or not working parts.if u want find as fast remove all the IDE from the board and remove the memory and VGA if you have then clean the memory using paper eraser all the pin connectors then try to put it back the boot the board/power..good luck
Posted on Jun 15, 2009
    New Friend:
Makes me laugh when I see people answering post like this that has no clue.
The red light is showing you that the memory has power supplied to it and nothing more
One green and one red light should be seen at all times
Posted on Mar 26, 2013
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
My ps3 shows a green lite then orange and stops whats wrong ?
This could mean there is a problem with adequate power towards the Motherboard within. Incandescent LED's/Light Emitting Diode's: used as colorful indicators, and often appear green, blue, red, etc... are sometimes bi~color, (that means 3 terminals per LED). This could be a power board problem. Maybe, try to Take to service Technician to analyze if its the Power board.
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
LED light has gone out
Lights up blue when the Drive is powered on. Flashes red when reading or writing data. It was just stuck between color as it does not flash green,red-blue make green. Contact the company and see if it is under warranty, if not see if they will send you a new light, because
if it is not under warranty,it does not matter if you open it.
All that is inside is a hard drive, chip board. The light plugs onto the chip board same as a fan plugs onto a motherboard. I hope this helps you and it is under warranty,or at least they send you a new light if not.
Mar 24, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Red colors have turned green
You most likely have lost red lamp function. This can be caused by a number of issues. None are going to be an easy fix. You can isolate the problem quickly if you are a tech, by doing a red/green gun driver board swap. Pretty much the only thing you can try to do yourself, is take the front panel off the TV, then adjust the color bias knobs usually located somewhere behind the panel. One will control the red, one for blue, and one for green. Mark them before you play with them, so you can return them to the factory settings if needed.
Nov 13, 2008 | Televison & Video
Motherboard Manual JFP1 Connector
Hi Pierre,
Though many MSI boards are similar, it would help if you would include the model number of your MSI board?
(Many times Fixya does not show your current correct model number but you can add it into your posted question). The pic's included below belong to the MSI K8N Neo3MB.
Look to page 2-16 (In manual). What is not included in the manual are the wire colors. Case wire colors do vary from case to case.
The colors: red, blue, green, light blue, light green & light red are commonly ( + ) = positive. The colors white & black are commonly ( - ) = negative. Some case wires-connectors are marked +/-, some are not marked. (The common color of each set of case wires is usually ( + ), positive)!
If your board is not like the pic's above than include your model number & I'll adjust my answer.
Good luck Pierre!
Mike
Nov 08, 2008 | Intel Motherboard
I need to know what colors mean what, so i can hook my cd player up
Red - Power
Yellow - primary power must be joined to the red
blue - Remote
Black - ground or negative
To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash.
or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right.
If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
Oct 09, 2008 | 1991 Honda Accord
My webcam shows only red
basically we use RGB color system so it contains color like red green and blue....in ur web cam settings u only increased the content of red color and u decrease the content of green and blue...so pls take ur settings and put all three colors to a same number...it means u have number from 1 to 100 and u can give the red green and blue colors up to this limit....so put green in 32 and red in 30 and blue in 32......then it will b corrected
Sep 20, 2008 | Logitech Webcam
Dash board green indicator light gone to yellow why
yes what does it mean mine is green is that good
Jul 02, 2008 | 1992 Honda Accord
Intel Motherboard Logo
652 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
