Question about EasyWalker DUO Base Stroller
Wheel has fallen off easy walker duo bolt is missing
Bit has fallen off front wheel
How do I remove and install steering column? Thanks
This all depends on what year the vehicle is? And wether there is an airbag fitted on the steering wheel front. If there is an airbag fitted on the steering wheel front, then the job is best left to a qualified mechanic, as the airbag sensor will have to be disconnected ( Disabled) and this can be very tricky. If there is no airbag on the front steering wheel cover then you will need a good socket set, remove the front cover of the steering wheel and undo the bolt holding on the wheel to the column, then you will see the rest of the bolts for the column at the rear, remove these also, take pics of the set up of wiring looms and bolts before! And keep all parts in a box for safe keeping.
Jan 18, 2015 | 1999 Oldsmobile Aurora
Do baby walkers teach babies to walk?
If only it were that easy :) I don't suggest you let your baby use a walked until he or she is very strong on their feet. Since walkers are on wheels, it's really easy for babies to fall and hurt themselves as the wheels more the walker too fast.
Jan 30, 2013 | Baby Gear
Front Wheels jammed up. Replace or cleaning tips?
I have the same issue did you ever get that fixed? I was able to clean the back ones with out a problem.
Jan 11, 2013 | Cosco Juvenile Cosco Beep! Beep! Walker -...
I have just purchased a Kawasaki 98 GPXR motorbike and need to replace the front wheel tyre. How do i go about removing the wheel so that i can take it to the mechanics to get this done?
Torque specs:
Front axle = 80 ft/lb
Front axle clamp bolt = 15 ft/lb
Front axle caliper mounting bolts = 25 ft/lb
Front Wheel Removal:
1. While the bike is still on the rear stand (but before putting it on the front stand), loosen the front axle clamp bolt with a 6mm hex bit. You do not need to remove it fully, just be sure it's loose.
2. Using the 14mm hex bit, loosen the front axle bolt. A breaker bar makes this step easier. Once it is loose you can go ahead and place the motorcycle on the front stand.
3. Using the 12mm socket, remove the front brake caliper mounting bolts. Once you have the brake off of the rotor, replace the bolts back in the caliper to prevent losing them. Hang the brake using cable ties or twine. BE SURE NOT TO PUSH THE BRAKE PEDAL! This will compress the brake pads and make it difficult to re-install. Repeat the process for the other side.
4. Once the brakes are tied off out of the way, finish removing the front axle bolt. It's helpful to use some wood to support the wheel while removing the axle bolt. Be sure to note the spacers on the wheel between the forks and the wheel. Remove them so they don't get lost. These will need to be greased before reinstalling.
5. Installation is the reverse of removal. Be sure to replace the calipers and torque them to 25 ft/lb. Once the front axle bolt has been torqued to 80 ft/lb, be sure to drop the front to the ground and bounce the front forks 4-5 times. This will seat the forks on the axle. Then you can tighten the front axle clamp bolt to 15 ft/lb.
Mar 26, 2011 | kawasaki GPX 750 R Motorcycles
Disney Baby Music & Lights Walker how to take off the seat instructions
Frustrating, as our manual is lost in the house. What I figured out is to take of the easy straps through the slots first. The tricky part is to get a grip on both sides of the tabbed front fasteners, twist and pull at the same time and they come out. I hope this is understandable.
Jan 07, 2011 | Dorel Disney Princess Music and Lights...
I cant the handlebars to turnh the wheel doesnt seem to grasp am i missing a part
Tighten the 7/16 inch bolt that goes down into the neck where the front wheel attaches to the frame.
Jun 26, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Does the front wheel bearing have to be machined
on that vehicle it,s replacement remove wheel remove brake caliper and pads remove brake caliper mount if you look on back side of spindle around area where axle comes thru you have three or four bolts remove bolts remove axle nut and hub bearing assembly comes off re-install in reverse order if this vehicle has 4 wheel abs unhook any wheel speed sensors
Mar 18, 2010 | 2003 Ford Explorer
Starter bolt broke off in diagonal hole toward front of truck
Can you drill a hole in the bolt get an ez out and remove it or get a center pnch and hammer and try to remove
Mar 20, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
Kolcraft tot rider 2 walker is missing a wheel where can I find a replacement wheel
There was a recall for model # 14302 which can be found at the base of the walker. Either way, you can call Kolcraft at 1-800-453-7673 or visit their website at www.kolcraft.com for replacement parts
Oct 09, 2008 | Kolcraft Easy Reach Ultra Light Vibes Crib
EasyWalker DUO Base Stroller Logo
27 people viewed this question
Top Easywalker Baby Gear Experts
Dorel UK
Dorel UK
Are you an Easywalker Baby Gear Expert? Answer questions, earn points and help others
