Question about Swann Communications Home Security
Swannn dvr4 950 no menu no pictures showing in my telly just says no signal on the telly. My dvr box has a green flashing light?
Swannn dvr 4 950 not showing on my TV at all
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
  • 140 Answers
SOURCE: sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Posted on Jan 06, 2009
  • 135 Answers
SOURCE: green light flashing under standby light and wont turn on
hthis is either a power peoblem or another board if it is still underwarrenty you can get it fixed with no charge
Posted on Jan 18, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
Swannn dvr 16 ch. model # N3960...plugged it in and says loading on tv screen but then turns off back to loading screnn then flashes off continuiously....thats with HDMI PLUGGED INTO IT
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Nov 03, 2016 | Televison & Video
LG 4200A
hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Jan 16, 2008 | LG 42LP1D 42 in. LCD HDTV
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
I have a 4 year old Mitsubishi WD-57831. Lately, when connected to my cable DVR via a HDMI, the picture flashes on and off and some stations don't come in at all. I changed the cable box 4 times, changed...
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Aug 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Does not receive 110 side
Hi a_mizrahi! I will be more than glad to assist you in thhis concern. If your model 510 dvr receiver dont get the sat 110. Lets check 1st the cable connection on the back of the receiver, make sure that the cable connected on sat in is connected hand tight and check as well if the cable is going to the wall with a connector as well. Then press the menu button on the upper left of the remote, it will pop up the main menu, once you got it, press number 6-system setup, 1 installation, 3 system info, It will show the system info one. check on the field letter g, you will see sat number, ex only 119, bcoz you cant get 110, check if sat 119 is green on the buttom box, if its green then select cancel on the screen, then select 1 pointdish, select on check switch then once you are on the install summary, select test on the buttom portionof the screen. It will run a test it could be 1 of 2 or depends on the situation of your sat dish.. wait till it finish. once its finish, it will show the install summary, check if you have, input1-119-all- device name, input2-110-all-device name, or it could show this way, input1-119-odd-even, input2-110-odd-even, if you got 110 on the input after the test it means that we are almost there to fix the problem.. select cancel on the screen, cancel all the way out of the menu until it will pop up attention 015, it should show a progress up to 5 of 5 then it will download the programming guide, wait until it finish the download and it will pop up a picture right away on the tv. let check if the 110 is ok, most of the channels broadcast under 110 is your local channels and some upper channels from the sat.. press menu and then main menu willshow, press 6, 1, 3, back to system info one, check on the field g if sat 119-green, 110-green, if there is no 110 showed on the field g, cancel alll the way out of the menu, then press the power button on the front panel of the receiver for 10secs to reset the system, it should show on the front panel of the box that the power light will turn off and turn back on by itself, then it will acquire the sat signal again, it will go to the process of finishing the progress and download the program guide again, just incase the front panel reset didnt work, do the hard reset by unplugging the power of the receiver to the wall outlet for 1minute. then plug it back in, it will go to the progress again and download the programming guide.. check again the sat on the system info one, by pressing the menu button on the remote, press 6,1,3, check sat 110 is there and 119, it should be green on the button. granting still no 110 sat, select cancel, then select on the screen updates - option 4 I think, once your there, check if without my permission is selected or check, then save , cancel all the way out of the menu, once you got a picture, press the power button on the remote to turn off the receiver, leave the tv on, wait for a few secs and it will pop up attention 061, downloading vital program information, this msg will appear if your software version is outdated.. wait until it finish and once its finish the tv screen will turn black or snowy screen and no lights on the front panel of the box. push the power button on the front panel of the receiver for 10secs to reset the box and wait till it acquire the sat signal and download the programming guide, this should fix the problem, if there is no changes, please call dish network tech support @ 1-800-333-DISH, to check your sat system, there is a possibility that there is a problem on the alignment of the dish, switch or lnbf..
Sep 02, 2009 | DISH Network DVR 510 DTV Receiver /...
No signal
Lets start from the top, first off do you have a cable box, antenna, or dish type service?
Mar 07, 2008 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Home Security Logo
21 people viewed this question
Top Swann Communications Home Security Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
 Mikey
Mikey
Are you a Swann Communications Home Security Expert? Answer questions, earn points and help others
