Question about Craftsman Variable Speed Rotary Tool Kit
Trying to change drill bit on Craftsman Rotary Variable speed drill
How do you change the bit on the rotary variable speed drill by Craftsman?
    Genius:
  • 1,406 Answers
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Posted on Jul 29, 2014
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
I cant loosen the bit on my dremel variable 395. The hole that the 'stop rotary pin' enters which stops the shaft from spinning is stripped out. The pin will not stay in place when I attempt to unscrew the...
Clamp the bit in a vise or with vise-grips (you will probably ruin it) to hold it while you loosen the collet. You can disassemble the tool and get the lock assembly P/N 2615297356 from for less than $2.00. Search for the part number on line for a source.
Jan 06, 2011 | Dremel Variable - Speed Multipro Rotary...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Drilling slowly
If the battery is OK then the problem will be in the variable speed trigger switch.
Sep 24, 2009 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Dremel 395 in the middle of drilling sea glass and the collet and bit stop turning while the motor is still running fine! GRRRRR Thanks for any suggestions!
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Jan 29, 2009 | Dremel Variable - Speed Multipro Rotary...
Speed Qeustion
Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes.
Aug 27, 2008 | Hitachi Rotary Hammer Kit 15/16,SDS, 0...
How do I change bits????
there is a screw at the tip of the dremel, take it out and it is pretty basic after that
Aug 05, 2008 | Dremel Variable - Speed Multipro Rotary...
Craftsman Variable Speed Rotary Tool Kit Logo
146 people viewed this question
Top Craftsman Crafts & Hobbies Experts
Kazim ERGUNEY
Kazim ERGUNEY
NOEL
NOEL
Are you a Craftsman Craft and Hobby Expert? Answer questions, earn points and help others
