Question about Swingline 747 Classic Desk Stapler, 20 Sheet Capacity, Black (S7074771H)
How do I reassemble my stapler
I took it apart to fix a jam and now I have all the pieces to put back together. Do you show that anywhere?
My black & decker powershot would not reset, so I took it apart. Now I can't figure out where the plastic piece goes.
I used the photo at the website. I printed the picture of the stapler, and after 4 or 5 tries, got it back together. It works just fine. Thank You very much.
Dec 28, 2009 | Black & Decker 5700 Powershot Forward...
My craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Nov 22, 2009 | Tools & Hardware - Others
REATTACH PARTS
Should slifde right together from the back. If you will go to the company web site, there is an exploded picture there for your convenience.
I hope this helps
a
Oct 02, 2009 | Arrow Fastener T27 Light Duty Household...
Need help to reassemble Swingline Optima desk stapler
You must have purchased the Swingline Stapler that is actually a Paper Weight. Do you have the 747 model, the one the airplane of named after?
Sometime the imbeded PC fails, preventing the robotic controls to release the staple or to reassemble automatically.
Please return for a complete replacement and a free trip to Disey Lane just pay for transportation, tickets, lodging, food, shipping, packaging, and handling. Have a nice day and thanks for flying with us.
Sep 15, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
Trigger jamming
I suspect that the cable to the carb is binding. Make sure when you reassemble the box, the cable works properly. Put the box together loosely and keep checking the action. Position the parts if it binds. Good luck!
Mar 20, 2009 | Echo Garden
Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Mar 15, 2009 | Stanley Tools & Hardware - Others
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
How do I reassemble On/Off switch?
The actual switch will not fall apart. There is a black part that is integral with the switch itself. This is about 1/4" to 3/8" wide, and can only be seen from inside the unit. Then there is a plastic piece that is part of the top shell. The hole in the plastic piece has to fit over the black part of the switch, so when the plastic piece is moved, the switch on the inside of the unit will move with it. SO, center both parts, and put them together. If you actually took the switch itself apart, you would have needed a soldering iron, and there would be no purpose for doing this.
Apr 03, 2008 | Fellowes P700-2 Shredder
Swingline 747 Classic Desk Stapler, 20 Sheet Capacity, Black (S7074771H) Logo
46 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
