Question about Husqvarna Garden
Not cutting short enough
It says in the booklet not to add more that 2 spacers , but it doesn't cut very short is there a half space or adjustment i can do as this is branf new petrol flymo
  • 708 Answers
There should be two sets of holes for the deck mounts. Check and see if it is in the upper or lower hole. Place in lower hole if applicable. Also ther is an adjustment nut on both side of the mower deck that has a jam nut and a gear nut. The gear nut adjusts the height of the mower deck on each sid here is link that might helpe. Loosen jam nut and turn to go up or down. Then tighten jam nut. This should be done on a level surface. here is a link that will help you as well.: http://homeguides.sfgate.com/adjust-deck-height-husqvarna-100712.html
Posted on May 10, 2014
3 Suggested Answers
panilling9
  • 284 Answers
SOURCE: does not give a short enough cut
Have you always had this problem?
Have you had the blades off to sharpen?
Could the blades have been mistakenly put on upside down ?
The turned up piece goes toward the deck
Check your deck hangers to be sure they are free and not binding anywhere and to be sure they are dropping as far as they can go in the lowest deck setting.
your deck should move up and down evenly as you lower and raise it.
Unless spacers are an option for this cause i wouldnt use them.
Check the tire pressure 14 psi front 10psi rear .
hope some of this helps for you
Posted on Jun 10, 2009
  • 2239 Answers
SOURCE: my flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Posted on Aug 10, 2012
Problem with 65 Chevy Malibu small block 350 flywheel and starter binding up.
Due to limited space...many of these cars required a spacer or two between the starter and flywheel...unfortunately you have to trial and error to find the right match...start with two spacers...then remove or add as needed...Hope this helps
Apr 06, 2015 | Cars & Trucks
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
Aug 10, 2012 | Garden
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
How do you adjust the height of the handle bars?
What kind of stem are we talking about. Modern stems are not adjustable other than to add or remove spacers under them or flip the whole thing over for a drastic change. Once cut to length the stem adjustment is very limited as you can't really get away with adding spacers for additional height. Beyond its current physical limitations you would probably need a different stem.
Here's a great resource that explains old-school and newer stems.
Mar 19, 2010 | Fuji Road Bike Saddle/embroidery/chromoly...
I cant seem to put the belt back on my whirlpool washing machine its not stretching enough. am i doing something wrong?
slide belt in before short spacer...then over brake lever then pump then put in spacer tighten 9/16 bolts evenly do not use short cut(cut belt) HI HI
Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Finalize a Disc on Mangavox MWR10D6
No. Generally finalising just writes the unused spaces as unused so the player knows and adds a stop code. The shorter the DVD the longer the finalise. An hour and a half on two hours is plenty of space.
Apr 13, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Sportster Wheel Spacer positioning
install wheel without spacers. axle has hole in it to align right side leg. center wheel and check spacing order. right side of wheel ussually has one spacer as axle is a part of its spacing.
Feb 22, 2009 | Harley Davidson XL Sportster 883...
Front right half shaft to short
Go kick who ever installed your lift for not doing it right. The front differential will have to be dropped the amount of the lift to make the axles work. You may have to install a slightly longer front drive shaft also.
Jan 06, 2009 | 2000 Chevrolet 3500
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Garden Logo
51 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
