Question about GE DCVH515EFWW Electric Dryer
Machine displays E 61 on the display and does not start
Machine has power on all legs will not turn on display shows E 61 what does this mean?
2 Suggested Answers
SOURCE: GE PFSS6PKW Displays 8888
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
Posted on Apr 11, 2011
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Describe your Epson im- 700 pos machine com portProblem Hi, We have IM -700 POS now its getting problem with printer and display. Showing com port error code 1001 pls any body can help
If you are getting display problem then
1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the moniter but in the computer
May 18, 2010 | Epson POS TMT88IV Thermal Receipt Printer
Have a Panasonic DMR that will not work, keeps showing U61 code
u 61 means-displays when a malfunction has occurred,playback or copy.this is displayed when the unit is in the recovery process to return to normal operation,it is not broken.once the display disappears you can use the unit again.
Apr 26, 2010 | Panasonic DMR-E55 DVD Recorder
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Sep 21, 2009 | Panasonic DMR-ES35VS
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Panasonic cd player sa-ak75 showing fault 61 on display screen,machine will not fire up regards derek
check fan it might not be rotating.the fan should rotate when increasing the volume.check also the power module ic
Mar 06, 2009 | Audio Players & Recorders
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
Samsung rs2578ww
littlern, Im thnking the 61 was your ambient temp on the refer side. The codes show up differnt than that. This is a very complicated machine. Sounds like a temp sensor has gone bad, the main board or the compressor overload itself. You can put it into a self diag mode by pressing power freeze and power cool together for 8 seconds. This is going to test all the sensors, fans, defrost cycles. The error that comes up will show as a - or | running clockwise on a digital 8 figure and then has to be decoded on a chart. For exampe: If the - is present on the bottom side of the 8 in the display, this means a a number 4 error which means a rerigerator fan error. It's gets pretty confusing, it's good you called the service tech. Make sure to get an extended warranty on this model..Catriver..post back.
Oct 01, 2006 | Samsung RS2578BB Side by Side Refrigerator
GE DCVH515EFWW Electric Dryer Logo
23 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
