Question about Bretford Office Equipment & Supplies
Bretford 3.66 x 3.66 projector screen will not go up
Motorized
I have a haninex 800 dlsinstdual 8 I can load it but do not know the controls to zoom,focus,etc
If this has a motorized zoom and focus then it will be on the remote listed as zoom and focus or on the hard buttons on the projector itself. If you don't have this feature then you must focus and zoom manually on the lens itself. There will be two tabs or rollers that you make these adjustments with this.
Feb 15, 2015 | Office Equipment & Supplies
Changing fuse on Bretford Mobility Cart 20
First thing to check is if the power cable has been pulled out of the power supply under the top surface of the cart. Ours was pulled up just enough to not power the cart, even though it looked like it was plugged in. If that isn't the problem. then you will find two wing nut screws holding the power supply unit in place. Unplug all three cables running to the power supply, then unscrew the wingnut screws. Lift the black rubber cover off the surface and you can then lift the power supply out. You will find a fuse location you can access with a flathead screwdriver.
Nov 13, 2013 | Bretford Mobility Cart 20 for MacBook and...
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
Hi! where can i purchase a 12 volt trigger cable for a motorized screen
Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
Oct 31, 2009 | Optoma Panoview Matte White Motorized...
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
70 people viewed this question
Top Bretford Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Bretford Office Equipment and Supply Expert? Answer questions, earn points and help others
