Question about NEC NP16LP Projector Lamp
Projector M300W don' t display on 1 mnt shutdown automatic
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Aug 24, 2016
NEC NP-M300W projector: Lamp status RED, replaced lamp still RED. Status indicator GREEN. Won't power on.
On the remote control of the projector, press and hold the HELP button for 10 seconds.
Aug 26, 2015 | NEC Office Equipment & Supplies
Have just replaced the lamp on my m300w projector and I van not get it back on it still has the Red lamp light flashing on it will not turn on any idea please
Here is the User Manual in case you need it:
http://www.necdisplay.com/documents/UserManuals/Mseries_UserManual.pdf
Did you use a NEC NP16LP lamp (M350X/M300W/M300XS/M260WS)?
If you continued to use the projector for 100 hours after the lamp reached the end of its lifr, the projector cannot turn on and the menu is not displayed. If this happens, press the HELP button on the remote control for 10 seconds to reset the lamp clock back to zero. When the lamp time is reset to zero, the LAMP indicator goes out.
Dec 17, 2014 | Office Equipment & Supplies
Why do i need when the projector is getting automatically shutdown
Sounds like an auto-shutdown or auto-sleep setting. Go into your System Setup>Basic Menu and check the settings.
Manual can be found here: http://benq.co.in/support/downloads/download.cfm?file=projector/manual/mp515 st/projector_um_user manual_20100524_151409mp515st 525st_en.pdf
Mar 13, 2014 | BenQ MP515 DLP PROJECTOR SVGA Projector
Nec NP-M300w computer inputs flicker on and off
It seems that the lcd panels are failed
Have a nice day!
Jerry
Lampdeng Limited
Mar 07, 2014 | NEC NP16LP Projector lamp RPLMNT LAMP FOR...
Replace lamp for NP-M300W
trun on the projector
menu-reset-clear lamp hours
Have a nice day!
Lampdeng Limited
Jerry
Feb 05, 2014 | 3M (EP7640ILK) Projector Lamp for MP7640
Projector will not turn on
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Jerry
Lampdeng Limited
Nov 22, 2013 | NEC 230W Projector Lamp for M300W
Projector M300W, with error Dynamic Contrast.
Have a nice day!
Jerry
Lampdeng Limited
Mar 18, 2013 | NEC Office Equipment & Supplies
My iomega ex hd wanted to reformat. it started but i stopped it before thew end. did I loose all the info on it
Unfortunately, you probably did. However, you do have a few options to fix it.
Option 1: Recover deleted files/partitions
Download the active@ partition recovery utility and try running that. I'm not 100% sure how this program works, so you might need to look around the site for some tutorials or something to get it working, but it seems like a pretty good solution.
Option 2: Rebuild the partition.
In order to do this you need to know what file system was originally on the drive. It will most likely be NTFS or FAT32. The best way to do it is to get a linux live cd like the System Rescue CD. Download the .iso file and burn it to a disk, then boot your computer from the disk. Keep hitting enter until you get a command prompt (should say root@sysresccd$). At that point plug in your external drive and wait a minute or two, then type "fdisk -l" (NOTE: That's an "ell", not an "eye". Also, don't type the quotes). You should see some entry on there for /dev/sdb, but it probably won't have any partitions at the moment, which is fine. However, write down the size of your Type "fdisk /dev/sdb" to enter the disk formatting screen. Now type the following:
n (to create new partition)
p (for primary partition)
1 (for partition number)
default for First cylinder
7 (for NTFS partition)
w (to write changes)
Next, type "ntfs-3g /dev/sdb1 /mnt/backup" and "ntfs-3g /dev/sda1 /mnt/windows". This will mount your external drive and internal drive to /mnt/backup and /mnt/windows respectively. Type "cd /mnt/windows" then "mkdir backup" to create another folder. Now type "rsync -av --progress /mnt/backup backup/" to copy everything available in your external drive to your internal drive. Hopefully you can get your stuff back, best of luck!
Tj
Aug 22, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
NEC NP16LP Projector Lamp Logo
51 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
