Question about Yamaha Tilt Trim Motor, 115-225 HP Outboard, Heavy Duty
Torque specs on 2001 f115tlrz yamaha 4-stroke outboard water pump
Torque specs on lower unit bolts
  • 86 Answers
SOURCE: im rebuilding my warrior
if your using the old bolts, 35 ft/lbs. if new bolts, 25 ft/lbs. that will work just fine.
Posted on May 12, 2009
RaidX
  • 632 Answers
SOURCE: what is the torque spec for the pressure plate
8.7ft lbs for clutch cover and 7.2ft lbs for pressure plate is recommended in the YZF-R1 service manual.
Posted on Jun 30, 2010
  • 518 Answers
SOURCE: torque specs 1982 yamaha xj550 oil plug and oil
settings should be in service manual.,
Posted on Jul 04, 2010
SOURCE: yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications Engine Engine Type
2-stroke Displacement
83 cc Bore x Stroke
47 mm x 47 mm Compression Ratio
8.2:1 Engine Cooling
Liquid Carburetion Carburetor
26mm Mikuni Transmission Transmission
6 - speed Chassis Wheelbase
49.5 in Ground Clearance
13.7 in Seat Height
33.6 in Fuel Tank Capacity
1.3 gallons Forks Forks
33mm Kayaba Fork Travel
10.8 in Shock Shock(s)
Kayaba Shock Travel
11.1 in Wheels and Tires Front Wheel
17 in Rear Wheel
14 in Brakes
disk/disk Other Information Intended Use
Motocross Color Scheme
Blue Cost when new
$3199
Posted on Jul 19, 2010
singingpreac
  • 54 Answers
SOURCE: i need head bolt torque
torque the head bolts at 35 ftp start at 10 going criss cross and then torque at full 35 fp.
Posted on Jul 15, 2011
Intake manifold torque specs 2000 olds silhoutte 3.4
Follow the link for a complete listing of this engines bolt torque specs. Torque Specs Database
Jan 25, 2017 | 2000 Oldsmobile Silhouette
03 Dodge Intrepid intake manifold torque specs top & bottom is for 3.5 V6
Lower Intake:
  1. Use a skin coat of RTV silicone on both sides of the water passage ports (outer most holes) and put the new lower intake gaskets into place
  2. Hand tighten the 13mm head intake bolts and Torque the bolts , starting from the center and working your way out in a circular pattern
  3. Torque these bolts in a few small increments until they have reached 250 inch pounds of torque.
  4. Upper Intake Plenum:
  5. When installing the intake air plenum , be sure to catch the four center bolts and the two side bolts (stiffener brackets) before tightening , The center bolts should be torqued to 250 inch pounds .The fuel rail bolts should be torqued to 100 inch pounds
Jun 24, 2016 | 2003 Dodge Intrepid
98 ford windstar intake manifold torque specs
Intake torque specs ' FordForumsOnline.com
www.fordforumsonline.com > Ford Tech Forums > Engine & Drivetrain
May 7, 2010 - 2 posts - ‎2 authors
ISO torque specs for the intake & plenum for a 98 Windstar...3.8 with the ... Our community is here to help you with any questions you have related to your Ford. ... Lower Intake Manifold to Cylinder Head Bolt 8-12 - (71-106).
Torque Specifications - AutoZone
www.autozone.com/.../Ford-Windstar.../Specifications/Torque-...
AutoZoneAutoZone Repair Guide for your 2004 Ford Truck Ranger 2WD 2.3L MFI DOHC 4cyl Engine Mechanical Specifications Torque Specifications. ... Ford Windstar 1999-2003 ... Bolts, Main Bearing Bolts, Rod Brearing Bolts, Crankshaft Damper Bolts, Flywheel Bolts, Manifold. Intake, Exhaust ... Vehicle: 2008 Ford F150, 98 Civic.
Dec 21, 2015 | 1998 Ford Windstar
What are the torque settings for bolts for the lower ball joint arm
Hi
The following torque specs apply :
8 mm Bolt - 55 NM
10 mm Bolt - 85 NM
12 mm Bolt - 115 NM
Regards
Martin
Jul 18, 2014 | 2007 Ford Territory 4.0
I need to know the torque-specs on the bolts for the CV shaft on a 1993 90 s. I need both the specs for the 6 bolts that hold the cv shaft to the transmission, as well as the 1 big outer-spindle...
Axle shaft bolt should be torqued to 147 Ft Lbs plus 1/4 turn.
The six CV joint bolts should be 59 Ft Lbs.
Ball joint nut should be 48 Ft Lbs
Hope this helps.
Sep 08, 2011 | 1993 Audi 90
My trw lower ball joint came with torque specs for the mounting bolts to 15ft.lbs each.. My trw upper ball joint came with no specs for the mounting bolts which are smaller bolts than the lowers, how do i...
I've replaced many ball joints, and never used a torque wrench. Just make them tight. If yours are the type with cotter pins, then you make it tight and slip in the cotter pin.
Sep 24, 2009 | 1996 GMC Jimmy
Yamaha Tilt Trim Motor, 115-225 HP Outboard, Heavy Duty Logo
62 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
