Question about RCA ViSYS 25423RE1 4-Line Telephone, Blue backlit LCD, Caller ID/Call Waiting, Enhanced full duplex speakerphone, 16 One-touch speed dial buttons, Hearing aid compatible, Headset jack, Switchable data port, Desk and Wall mountable
Reset voice message
I would like to reset the voice mail recording on the phone
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
My phone says I have voice mail but I don't
You're apparently subscribed to a voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 02, 2012 | Panasonic Lands Phones
I don't know how to set up voice message
If you mean setting up voice mail out-going message, then see below (for AT&T cell service). The phone will dial the voice mail center for you after you set it. Then it will check the number of messages on the system. Press Menu > Messaging > Settings. Then select Voice Mail and enter the phone number for the call center. Then press the AT&T button to exit.
To listen to the messages, press and hold 1 or press Menu > Messaging > Voice Mail. Then the number set above will be dialed.
To set up the voice mail box, start as you would for listening to the messages above. Note: you must use your wireless phone and be inside the AT&T coverage area.
To set up your voicemail box:
1. Follow the prompts to create and enter a 4- to 15-digit voicemail password.
2. Record your name and personal greeting, then press the # key
3. After completing the setup process, press * to return to the Main menu.
See http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=browseTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=52653&isSrch=Yes for more information.
For another provider, see their documentation.
To create a memo for yourself, press Menu > Tools > Voice Memo (or if using the advanced menu, Menu > My Stuff > Tools > Voice Memo). Then press Options > New (or Create New, if you have created one before). Press Re-rec to record and pause to momentarily stop recording. Press the AT&T button to stop recording. Press Play to play back a memo and the AT&T button to stop play-back.
I hope this helps.
Jan 29, 2011 | Pantech breEZeTM Cellular Phone
Lost the manual and need to record a new voice mail message
to leave a voice mail message on the Samsung Prostar;
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
Jan 22, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
Jun 19, 2009 | Panasonic KX-T7630 Corded Phone
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Remote call forwarding/message retrieval; record voice mail message
i found my solution on the AT&T website.
thanks anyway.
Mar 31, 2008 | AT&T 950 Corded Phone
Voice Mail recording
If you call into your voice mail you should get passed all the messages and it will say something to the fact of personal settings.. in there you can change your greeting.
Feb 18, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Recording messages
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well.
The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals.
So, your first step is to find out the model number of your phone system and voice mail system.
Oct 09, 2007 | Panasonic KX-T7633 Corded Phone
RCA ViSYS 25423RE1 4-Line Telephone, Blue backlit LCD, Caller ID/Call Waiting, Enhanced full duplex speakerphone, 16 One-touch speed dial buttons, Hearing aid compatible, Headset jack, Switchable data port, Desk and Wall mountable Logo
23 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
