Question about Sunbeam Food Mixers
Bowl won't turn
The bowl won't turn when mixing.
Brand new Kitchen Aid. Loose Bowl,
go talk to the place you bought it .
Dec 09, 2017 | Food Mixers
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
Need a new bowl
Sadly FIXYA has no control or ability to FIX the problem you have with the mixing bowls you ordered that are not the correct configuration for your mixer. suggest you contact the manufacturer again
Aug 17, 2017 | Oster Stand Mixer model: Fpstsm5102
KitchenAid KSM150 bowl won't stay put
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
Jul 08, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
The top of the mixer began shaking and thumping when running, I realized the tilt head is pressed forward a little too far, causing the basic mixing attachment to press too far down into the bowl, maybe by...
Tip the machine upside down on a towel, centralise the hinge pin and tighten the grub screw that locks it into place. This is right up inside the pedestal, there is only one screw there to see.
Now stand it up and fit the mixing bowl & flat paddle, turn the machine on speed one, if the paddle is tinging on the bowl then we now need to set the head height. Turn the motor off.
Raise the motor up and from the front of the machine look in by where the motor hinges on the pedestal. You can see one screw head there. If it's tinging the bowl then you need to turn the screw anti clockwise enough so that the paddle no longer tings on the bowl.
Once it's stopped tinging put it onto max speed and make sure it still clears at high speed, if not turn the screw until it stops tinging. That's it.
Jan 02, 2018 | KitchenAid K45SS Classic Stand Mixer
Sunbeam stand mixer's mixing bowl does not turn when mixer is on!
You may have a product failure. Yesterday's Sunbeam is not today's Sunbeam.
Dec 03, 2017 | Sunbeam 2353 Stand Mixer
Food Mixers Logo
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
