Question about Ricoh Aficio CL7200 Laser Printer
PRINT LABEL WHAT PAPER TYPE SETTING?
Print vertical on the p touch 1830
You need to go to printer setting and go to print type. now you will able to see your paper printing type. you need to click on that and select A4 paper size.
Feb 21, 2015 | Brother P-Touch PT-1830 Label Printer
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
I have got a datamax m class mark II and i have got a fault top of form and i can not print anything or i can not connect to printer from my computer. i have all drivers on and i think all is fine but i...
1)PLACE THE SENSOR IN TO THE LABEL GAP PROPERLY 2)CHECK THE SENSOR TYPE IN PRINTER(menu->media settings->sensor type) 3)PERFORM A MEDIA AUTO CALIBRATION(press and hold feed on control panel) 4)SET FACTORY DEFAULT SETTINGS
Apr 15, 2011 | Datamax M-4208 Thermal Label Printer
Kodak printer will not print on avery label paper. Have been on teck support with anurag s for about an hour and tried again to print labels.
Hi , i have been using avery templates and label paper at work for ages and always printed off without problems on my lexmark . I bought a Kodak however and all of a sudden I could no longer print off my labels , when I put paper in it just came out blank and said paper wrong size .I could not find any solutions at all and was tearing my hair out . I just kept trying different things and all of a sudden I changed a setting and it worked perfectly.When you go to print your label change the ' scale to paper size ' function to A4 and then it will print.
hope this helps
Feb 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot print...mmm...on this paper
The printer will not print the settings dependant on your media between 2 across. The printer figures you have one label wide enough to print the config page. Is there a reason you are trying to print this? You could set the printer driver to print to a file instead of the printer and get the settings that way. Or, if you are connected via TCP/IP, you can view it on the internal webpage of the printer.
Jun 22, 2009 | Zebra S4M Thermal Label Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Cannot print Labels
The printer is setting the size from the position of the tray guides.
If it is reading it as K16 then that is the closest size to the paper you have loaded. The device will oook at the tray and then set it to the closest match this is the function of the Auto size feature.
Try measuring the paper and entering it as a custom size instead. Mimic the setting through the driver of course.
Run it through the bypass tray and be sure to specify the stock type/weight for proper printing.
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Ricoh Aficio CL7200 Laser Printer Logo
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
