Question about Staples SPL-P100 Printing Calculator
Is there an item count feature on the spl-p100 model
Item count with total
Why are totals rounding off
In the product details of this calculator, it states that there is a "decimal point selector." This is normally a slider starting with the letter F followed by the numbers 0123 etc. It is probably on 0. You can set the number of decimals to whatever you want, or use F for full numbers. For example, if you set this to 2, you should always get 2 decimals.
Good luck,
Paul
Apr 07, 2016 | Staples SPL-P100 Printing Calculator
Set time and date for SPL-P100
You will have to find the manual because it is not online.
Mar 05, 2015 | Office Equipment & Supplies
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
What is the difference between the VX2652H and the VX2652B?
The Sharp VX-2652H is a commercial calculator that prints in 2 colors, extra large display,Special features include 3-level (sub/total/grand) totaling, markup keys, tax keys, a 4-key memory and item count. AC operation. 2.75"H x 9.83"W x 12.5"D.
The Sharp VX-2652B is a scientific calculator,
Quick and quiet 12 digit print/display calculator with stored memory tax rate key and 4 key memory. Large, easy-to-read 12 mm display.Features .Comfortable Cylindrical Step-sculptured Keys . designed for fast and comfortable operation. Extra ease is provided by contoured Plus/Equal and Minus/Equal keys.
So the difference is 1 is a commercial calculator and the other is a scientific calculator.
Sep 07, 2010 | Sharp VX-2652B Calculator
Track number of entries
on the top right there is a slide button ...move the button to "item". this counts the quantity of items you enter. hit the * to get the total and the count.
Aug 14, 2008 | Canon MP-25DV Calculator
Add number of checks
on the 5660... on the printer tape there is "off" "on" IC (for item count) and GT (which might be grand total)
for every entry of $check you add the item count will total to the left of the register tape.
May 20, 2008 | Texas Instruments TI-5660 Calculator
Item Count
The item counter isn't available on this model.
Apr 20, 2007 | Casio DR-250HD Calculator
Staples SPL-P100 Printing Calculator Logo
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
