Question about Staples SPL616X Cross-Cut Shredder
Green light is on but motor not running
Doesn't work in reverse either, the green light is on the overheat light is off
What causes 1996 Dodge Neon SOHC automatic transmission to delay or slip shifts?
that is a hum dinger, largest ever posted, in one shot.
very good.!
one word , the transmission slips. (never drive a slipping tranny)
overheat indicator.! that is key.
many newer cars will change the transmission shifting any time
the engine over heats.
and overheat wins over transmission , every time.
if the engine burns up, what good is any transmission.? nada.
solve overheat first.
slip or flare.
is when the engine RPM rises fast and the car dont go faster.
SLIPS.
and slipping burns up trannyclutchs and increases the damage. inside the transmission, dont do that. dont allow it,
park it and fix it.
on some tranny there is a temperature sensor that the TCM
watches and changes shift patterns based on AFT fluid temps.
and if the ATF fluid gets too hot , it takes actions. to keep the tranny from harm.
why not get a scan too and see what DTC errors there are..
DTC, engine overheate.
DTC< tranny overheat (caused by above)
Jun 14, 2014 | 1996 Dodge Neon
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
On a 2001 saturn L series, 2.2 litre automatic. gas gauge doesn't work and the temp light blinks continuously while the temp gauge needle jumps continuously. i've checked the coolant levels,th
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 12, 2012 | 2001 Saturn L-Series
Are the back up (reverse lights) in series---where if one bulb is out neither side works---on a jeep cherokee?
no, they are 12 volt bulbs and require parallel wiring. If you have a manual transmission, check the reverse light switch on the transmission for continuity with the transmission in reverse. If you have an automatic, the reverse switch is integrated into the transmission range switch at the shift cable attach point. In either case, the wires at the switch are yellow/dark green stripe and brown/light green stripe.
Dec 16, 2010 | 1993 Jeep Grand Cherokee
Stopped working while i was using it
Mine does that when it jams, or overheats. Try toggling the switch between forward and reverse to clear any jam. If that doesn't work, you can unplug the unit, turn it over, and remove jammed paper with needle nose pliers.If there is no jam, try letting it cool for a while and then try in the reverse position.
Oct 29, 2010 | Staples ID Armor IDX50B Shredder
Wiring 4 way flat trailer plug. brown wire running
you got brown for running parking light
green for right turn/stop
yellow for left turn/stop
white for ground
reverse lights are only wired on a 6 or 7 plug connector
make sure you on the dark green for right turn stop not the light green
the light green is for reverse
Jun 24, 2010 | 1999 Chevrolet Tahoe
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Staples SPL616X Cross-Cut Shredder Logo
56 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
