Question about SanDisk Sansa Clip MP3 Player
My Sansa Clip has worked for years and years, and I've loved it, but lately it keeps shutting off, I've checked the power and sleep options too btw, without me telling it to. I was just wondering if
It just stops and was hoping someone could help.
    Master:
  • 426 Answers
There's a good chance that it's the battery.
Posted on May 18, 2014
SOURCE: SanDisk Sansa Clip is stuck on connected.
hey it happened to me before for about 10 minutes try to hold the power button to off for a bit then let go if it doesn't work try it again...
i got mine on the 5th try... it takes patience
Posted on Dec 31, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa clip shutdown
Firmware Upgrade
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa clip
You don't need Vista to install the Sansa Clip. Run the installation CD (or grab the software from Sandisk's website), and plug the player into your computer.
Posted on Sep 07, 2008
SOURCE: Sansa Clip 2GB won't transfer songs
I had a similar problem with with one of my mobiles, so not sure if it applies in this case, check the ports, and make sure the device is connected to the correct usb port that the pc has allocated to your portable device (sansa clip)
Posted on Oct 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Sansa clip went dead
Slide the power button on your SanDisk Sansa MP3 player up.
  • 2 Hold the power button on your Sansa in the up position for about 15 seconds. This action serves as a powering down of the Sansa device.
  • 3 Wait for your Sansa MP3 player to restart and let go of the power button. Actions taken during your last operation since powering down normally have been deleted and your player is now reset.
  • Oct 19, 2011 | SanDisk Sansa Clip MP3 Player
    I recently purchased a Sansa Clip MP3. I downloaded audiobooks to it but they will not play. What do I need to do?
    Not true!!! The Sansa Clip is actually the best mp3 player I have found for listing to audiobooks. Here is what you need to do. Download the latest firmware update on the Sandisk website. You must do this or it just won't work unless you are downloading books from Audible.
    I use the Overdrive Media Console and download mp3 and WMA books from my state library. When you hit transfer, be sure it hit advanced options. Browse until you select the audiobook folder on your player. Then transfer to that.
    The player will bookmark your last place on anything that is in your audiobook folder. You can easily switch back and forth between your music and book without losing your place! Love it!
    It even has a sleep timer on it. I'm in heaven.
    Apr 27, 2010 | SanDisk Sansa Clip MP3 Player
    Laptop keeps shutting itself off
    Check the power settings - most laptops are set to sleep even if plugged in to AC power - go to Control Panel -> Power Options and check for sleep/shutdown settings under "Plugged In".
    Oct 20, 2009 | Computers & Internet
    My sansa clip isnt working
    After you disconnect the mp3 player from the PC, it will go to sleep. To turn it back on, slide the power switch on the side to the ON position for about 3-5 seconds, and the player wil lturn on. Make sure the hold/lock was not accidentally engaged first.
    If your problem is more serious than that:
    -Tha Mp3 Doctor
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    It shut off.
    Turn it on by holding in the power button - it is normal for that model to go to sleep while it is playing, as a powersaving feature - but it shouldn't stop playing the music, the screen should just go away. Usually pressing any key will wake it back up.
    -Tha Mp3 Doctor
    Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
    Won't turn on
    Make sure the hold/lock switch is not engaged.
    -Tha Mp3 Doctor
    Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
    Sandisk sansa clip mp3 shuts of and wont turn back on...
    -Tha Mp3 Doctor
    Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
    Sansa clip shutdown
    Firmware Upgrade
    -Tha Mp3 Doctor
    May 20, 2008 | SanDisk Sansa e250 MP3 Player
    Can turn on
    The Sansa can sometimes break overnight if you sleep on it. This happened to me. I don't think this is really a solution, but if you bought it at BEST BUY, they have a 2-year guarantee for a new one.
    Sorry,
    Big Tony
    Jan 24, 2008 | SanDisk Sansa Clip MP3 Player
    SanDisk Sansa Clip MP3 Player Logo
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
