Question about Boating
Wont start 115 mariner
1997 115 horsepower Johnson, runs very lean cold. I have a hard a time starting, the fuel lines and primer bulb seem ok.
I have re-categorized this from chainsaws to the closest thing I could find to Johnson Marine Outboards. Let me know if this is incorrect?
Have you changed the fuel filter lately. Are there any kinks in the fuel lines. Is the automatic choke stuck? Sometimes it is just better to get a marine engineer to take a look. You don't want to burn through the top of a piston 12 miles out!
May 02, 2015 | Boating
Motor wont turn off with key
Could be broken wire in loom,or bad connection in loom plug or faulty ign switch which is very unlikely
Mar 17, 2014 | Clymer Marine Maintenance and Repair...
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
Sep 29, 2013 | Clymer Marine Maintenance and Repair...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Jun 20, 2009 | Boating
Boating Logo
20 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
