Question about Casio G-Shock G2600 watch
Don't know how to change time
It's water resist,black
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
Is the Sharp watch shp5759 waterproof
No such thing as a waterproof watch in the USA. Watches are rated for resistance to different depths. If it just says water resistant it means you don't need to remove it to wash your hands. If it doesn't say anything it is water resistant.
Oct 01, 2012 | Watches
I have water condensation in the face of a brand new (bought from an ebay watch store) bulova water resistant (up to 100m - it says 100m on watch face) women's marine star watch. what are my options?...
If you have registered your watch with the maker, then it is bes to send it to them (talk to them about it first- go to Boluva.com and look for service centers).
The seller would probably just send it off anyway and increase the delay time to gettingit back.
All work should be done by one of their service centers or an authorised dealer, in order that the warranty is not affected.
With a cheap watch the answer would be to remove the back and put it in a warm dry place for a day or so but as yours is not in that catagory, I would not advise any DIY methods.
I know its' a pain to loose your watch for a time but only accredited service agents can guarantee the water resistance it a watch is opened.
Jul 23, 2011 | Watches
Are fossil 10 atm watches water proof?
No watch is "water proof." As a matter of fact, there's a U.S. law on the books that watches (and other equipment) can only be described as "water resistant," since nothing other than a solid object can completely shed water.
All that said, the 10 ATM designation is meant to convey that when the watch was new, it was supposed to withstand up to 10 atmospheres of external pressure--which would translate into being about 300-330 feet underwater. That's pretty water proof in my book.
HOWEVER, and this is a big caveat, a watch's water resistance rating is based on its condition at the time that it left the factory. Over time, the little gaskets that help keep water out of the watch will begin to wear and provide less water resistance. In particular, official factory servicing states that the neoprene gasket between the case and caseback of the watch should be replaced every time that you change the battery. In fact, most people, including me, re-use that gasket if it still looks pretty good when I open the watch. That definitely compromises the factory water resistance rating.
Bottom line: If you have a watch rated for 10 ATM of water resistance that's a few years old, I wouldn't be all that concerned about getting it casually wet, or even going swimming with the watch (I'm paranoid enough that I wouldn't do this, but I'm probably in the minority). However, I wouldn't go diving with a watch that's had its battery replaced unless it was re-tested for water resistance after the battery was serviced. Some but not all jewelers have special machines that perform this test. If you're interested, you could probably pay one of them a few dollars to have your watch tested. They don't have to do anything to the watch other than place it in their machine, so it's not a big deal for someone who has the equipment to perform this test.
May 20, 2011 | Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
I dont know how to change the time? I have no
to press left side upper button and right side butom button to set the time
May 16, 2010 | Casio BabyG Shock Resistant Blue Sports...
I would like to know if the casio 3736 watch is water resistant because I found only the phrase water resistant 5bar
"Water resistant 5 bar" means that it is water resistant to and depth of 50 meters. (1 bar is approximately equal to 10 meters of water depth).
Apr 09, 2010 | Watches
Lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Jan 11, 2009 | Bulova Watch
Casio G-Shock G2600 watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
