Question about Radio Shack TRC-447 CB Radio
Cb radio where can I buy a cb radio and antenna and have them installed in the chicago area?
    Problem Solver:
  • 6 Answers
Re: cb radio
Radio shack and local truck stops...and i like the big whip antennas!!!! they are nice
Posted on Jan 08, 2009
  • 126 Answers
Re: cb radio
I tried looking up cb radio shops on google maps for you, but only find Radio Shack. You can always check close to your bigger truk stops, that is the normal place for an actual cb shop to be located. You can also ask the truck stop employees where a local cb radio shop is located.
If you were closer to Texas, I would help you out. But most major cities have a cb shop close to the major truck stops, such as Petro, Flying-J, Pilot, Loves. Some even have cb radio shops inside them.
If I can be of more assistance, please feel free to email me:
Rollin CBs
Mt. Vernon, TX
Posted on Jan 23, 2008
0 characters
3 Points
Installing a echo board into a Realistic 5 pin mic.
95% of realistic mics are 5 pin It would be easier to install it inside the radio.Better than that you buy a noise toy that hooks to the rear of the radio and then your antenna hooks to the toy.
Mar 07, 2014 | Galaxy Radios DX-2547 40-Channels Base CB...
Installing city lite noise toy to cb radio
just buy a remote one that hooks to the antenna output and the antenna hooks to it. Save your radio. If you sold it and the person you sold it to didn't want a toy then you would have to remove it.this way you can remove the toy and use it on another radio,or sell it too.
Mar 12, 2013 | Cobra 29 LTD CB Radio
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cb radio in the car and one at home if i got out in car i get about a mile and then no one at home can hear me but they can hear others can you help
radios are very picky beasts, the first thing you should do to get more range out of them is have them tuned by a cb dealer, from factory they rarely get out very far. also for the one that goes in your car antenna placement is very critical since your car body affects how the signal travels. even the length of antenna cable has a effect. when you have them "tuned" many times they will clip a resistor or "limiter" inside the unit. if you look up cb modding, youll find pages with 100s of makes of cb's and learn what modding them means. also look into high gain antenna for your units, if you want really long range buy a linear antenna "illegal in a lot of places" but you will be heard! people have used high gain antenna, and "skip" to talk to people in other states and countrys. skip is when the radio signal "skips" across the uppter atmosphere and uses it like a really big antenna. a lot of truck stops will have a good selection of antennas because cb is still very popular amongst truck drivers. i hope this helps you out and leads you in the right direction. cb is almost a lost art now and its nice to see people that are interested in it. take care and good luck!!
Jan 15, 2010 | Maxon MCB-30 40-Channels Base CB Radio
On my 77-099 Cb MIDLAND Radio I wonder can i use a antanna that is used for vehicle can be made for a home base radio place.I BOUGHT A MIDLAND CB RADIO AND MADE IN TO A HOME BASE RADIO THAT IS MADE FOR...
Generally this is not a good idea. The antennas that are designed for use with a car, use the body of the car as a ground plane. If you try to use this in a house (or even outside the house), it's not going to work.
Your only chance at even getting such a setup to work would be to attach the antenna to a LARGE flat piece of metal, approximately the size of a car, which is then grounded with a long metal rod into the earth.
I'd really suggest looking into buying a proper home CB antenna, which would then need to be mounted somehow to the roof of the house (or as high up as possible.) If this is not a feasible option, you should do a Google search for "CB Dipole Antenna", and get instructions on how to build and tune your own antenna. Dipoles are not overly difficult to construct, and perform quite well.
Nov 08, 2009 | Midland 77-099 CB Radio
It doesnt work
There may not be much chatter (people talking) in your area. Try to find a local CB friend who may introduce you to the CB world.
The 2 antennas idea does not increase input or output, in fact they (without additional high powered equipment) cancel each other out. Most CBers will only connect one antenna and have another installed and not connected but only for cosmetic reasons. Its only once a very high power threshold in reached that 2 connected antennas will be a benefit. Those are the ones that there output bleeds all over other peoples TVs and AM/FM radios.
Good luck
Mar 30, 2009 | Cobra 19 DX IV CB Radio
Procedures to install cb antennae mount
The end without a connector was once attached to an antenna. You need a proper antenna in order to use the radio. If you were to buy a new antenna, it will come with a length of cable attached. Even if you were to buy a new antenna, don't expect good performance from the radio unless you get the antenna properly adjusted. Yes, it will work "out of the box", but probably not as good as it could. There is a device called an SWR bridge, it's used to measure the SWR and the user then adjusts the antenna for the lowest reading by trial and error adjustment of the antenna.
Jan 23, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Cobra 200 GTL DX 3rd edition Installation
Hello John. A good earth ground for your antenna is more important than for the radio. Using the closest possible point to the antenna pole, preferably within a couple of feet, you need to ground the antenna pole to the earth. Go to a hardware store and buy a copper grounding rod which will be eight foot long and buy, as little as you can possibly get away with, some of 10 gauge wire and some kind of clamps that will attach the wire to the antenna pole and to the grounding rod. Google "antenna earth grounding" may help also.
Apr 03, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
I'm Thinking About a CB Radio
Hello Donna,
I do a line by line reply to your questions:
Q) Do C B Radios work from electricity, too, or just from a vehicle?
A) You will need to buy a 12volt power supply to power the CB if you are using it in your home. Also you will have to have a house mounted antenna.
Statement) I don't know what brand of C B Radio to get. I'll need one with tech support.
Reply) For simplicity, I would suggest getting a Realistic brand CB from Radio Shack, they will also have the antenna and installation hardware (for home and vehicle) along with a SWR meter (you will need this, trust me). As for tech support well any brand you go with will be a problem in the area of tech support, most of the time you will have to find a CB shop or some that is CB savvy to act as your tech support.
I hope this helps
Nov 16, 2007 | Radio Shack TRC-503 CB Radio
Radio Shack TRC-447 CB Radio Logo
208 people viewed this question
Top Radio Shack CB Radios Experts
Are you a Radio Shack CB Radio Expert? Answer questions, earn points and help others
