Question about Wolvol Boys Black Computer Laptop Mini Android 7inch Computer WIFI - FAS
My wolvol 10 inch mini laptop wont turn on
Had it from new its been on charge for 4 hours now the red light is on to show its charging
    Master:
  • 425 Answers
Does it feel hot under neath? might be the parts are getting fried, did u check the air vents for dust? call customer service at wolvol and see if they can help
Posted on Aug 18, 2014
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My brand new madcatz bluetooth headset wont charge, when plugged in the charging light is red, but it increases/ decreases in brightness after 4 hours it will not turn on or sync. This is the second one...
i just got mine and it when i plug it in to charge the red light turns on for like 10 seconds then turns off and it wont turn on so itss dead... return it?
Aug 29, 2010 | Mad Catz Bluetooth Headset for PS3
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
Wolvol Boys Black Computer Laptop Mini Android 7inch Computer WIFI - FAS Logo
135 people viewed this question
Top Wolvol Computers & Internet Experts
Rick Arnold
David Payne
David Payne
Are you a Wolvol Computer and Internet Expert? Answer questions, earn points and help others
