Question about Nordic Track Exercise & Fitness
My treadmill is making beep noises and stop working. What should I do?
Nordic track
joboo1
  • 257 Answers
SOURCE: my Nordic Track E 4400 treadmill sqeaks loudly when in use
Hi again, OK thanks, The belt slides on a track and can get debris or other things that stick and is probably causing the squealing. There are belt cleaners and dressings and lubricants but the best place and the best product for your treadmill can be found at this site:
www.TreadmillDoctor.com They offer many bits of advice and how to on many different kinds of treadmills and can tell you how to clean and apply their product. Good Luck to you, this should Fixya!
Posted on Mar 25, 2009
  • 175 Answers
SOURCE: Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
My t7 si is beeping continually and starts for a few seconds and stops
lube the deck belt+rollers bearing . If the problem persist, time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
My treadmill only beeps when i press a command
Is it running? Please call Treadmill Doctor at 800-750-4766 and they will diagnose it for free. Make sure you have your make, model and serial number ready.
Thanks
Jul 05, 2012 | Nordic Track NordicTrack Treadmill, A2550
The belt is tracking to the right side. I tried to adjust it using the hex key, but that seemed to make it worse. Also, when running, the seems to stop or jar under my feet. The motor makes a whining...
It sounds like you have a bad bearing. If you are not familiar with repairing/replacing bearings on a treadmill, I suggest you contact NordicTrak and have a tech come out and repair it.
Jan 06, 2011 | Nordic Track NordicTrack A2750 PRO...
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
We have a Nordic Track NTL09007 C2500 that has stop working the Digital Control lights up, but nothing works...Nordic Mfg want to sell me a new Console for $515.00 about half of what we paid for the...
Got beeping? I JUST figured out how to fix it. Take the console apart and pull the connector from the back of the iFit card adapter. Plug back in, should be good as new!
Oct 09, 2009 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
22 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
