Question about Black & Decker Irons
Iron is not getting hot
The iron will turn on with no problem but it just not heat up
Can't seem to prime iron to get the steam coming
  • if your having trouble getting the water in the iron to steam, try turning the heat setting all the way up and then add cold water to the resivoir. your iron may not be getting hot enough
Oct 11, 2014 | Irons
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
I cant get my iron to get hot enough it gets warm but then the light will sut off and it will stop heatting up
The problem lies with the thermostatic control. Check that your control knob has not been incorrectly replaced on the thermostat shaft and that you have full turning motion on the knob, it should turn about 3/4 turn from stop to stop. The thermostatic control is adjustable, but to do this the iron must be stripped.
Feb 02, 2011 | Maytag Irons
My iron will not consistently get HOT.
Hi.
The clicking sound is given by the solenoid that turns on and off the iron element. Heating cannot be turned on, and the iron keeps clicking without making any heat.
The cause of the problem can be a defective solenoid, a broken contact, or an open thermistor (it will turn the solenoid back on). The oven must be taken apart and tested to find the fault.
Regards.
Mar 02, 2010 | Rowenta Irons
My iron turns off when its hot
Thermostat bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 09, 2009 | Euro-Pro Shark GI490 Iron
Iron will not get hot
I suspect that the Irons heating element is coated with calcium, try using a couple of tablespoons of vinegar in a glass of water and let it sit overnight then rinse.
Mar 24, 2009 | Irons
Euro-Pro Steam Generator G6200H iron
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
My iron will not heat up to the hot postion
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Apr 03, 2008 | Rowenta DX6700 Iron
Irons Logo
26 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
