Sharp wf 969z
Tape go fast
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
How to receive fax
Driver (v1.63) 15-Jul-2014 18.36 MBs
  • Version: 1.63
  • Release Date: 15-Jul-2014
  • File Format: EXE
  • File Size: 18.36 MBs
Epson WorkForce WF 3010DW
download and install
Aug 06, 2014 | Epson WorkForce WF-3010DW Inkjet Printer -...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
Tape is stuck in the vcr and when you turn on the power it turns the tape about 10 seconds and then shuts off the power.
if the tape has snagged inside, the only way to get it out is to take the top of the vcr off and manually remove it. very simple procedure. only use your fingers and not anything sharp. have you tried rewinding the tape (from STOP mode) sometimes tapes can end up being wound very tight which would have the same effect. if you can rewind do so, then fast forward until tape stops, repeat this a few times this should loosen the tape.
Sep 21, 2008 | Televison & Video
Tape wont eject
Veri8fy that the belt on the side of the VCR mechanism is intact. If it is, then check that the motor works, by appying 12 volts to it,with the belt disconnected. If the motor works, it might be that your mode switch needs cleaning, and that takes some fancy unsoldering and soldering.
Sep 06, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Symphonic Model# SC319A
did you try leaving a tape in the vcr?mine did that and when i left a tape in it worked fine. good luck.now i cant get a tape out...lol
Jul 17, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
42 people viewed this question
 Grubhead
Grubhead
