Question about Danby DWC044BLP Wine Cooler
Does not cool
Condenser hot. compressor does not kick in.
My ac fan works but the compressor won,t kick on
The fan on the condenser or air handler? Check the capacitor on the condenser. If you don't have a meter that does uf you can take the amp draws of the comp multiplied by 2650, divided by the voltage between com and herm on the cap. If cap is good be sure compressor is not off on thermal overload, cool with water hose, careful to not soak electrical. If not hot and cap good , try hard start kit. If still no compressor ,ohm compressor, com to start plus com to run should equal start to run on ohms. Hope this helps.
Apr 04, 2016 | Heating & Cooling
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
Upright Freezer won't Cool
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 14, 2012 | Frigidaire GLFH17F8HB Upright Freezers
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Sunbeam chest freezer SBCF5WBX appears to operate but suddenly stopped being cold. It defrosted and thawed contents. Power is on and all electric lines and connections are in good condition. Freezer is...
Where you say that it appears to operator, do you mean that the compressor is working? If so, then your condenser grills might be dirty and causing the unit not to cool effectively. Is the sides or back of the unit getting hot? If so that could be the cause - a cleaning of the condenser coils.
But if your compressor is not kicking on or is very hot to the touch, then it might not be operating correctly. If it is not activating then it could be the contactor-relay or start capacitor.
Sep 10, 2011 | Microwave Ovens
I have a Magic Chef Refridge MCBR 1010W that has stopped cooling, fan runs and you can hear it kick in but then kicks off? An Ideas?
If the compressor kicks in that tells you the compressor relay and board are probably good. HOWEVER, when you say it kicks off right away that is not a good indication! It sounds like a compressor problem. Is the compressor extremely hot or is the condenser coils icing up? If so, I wouldn't invest the money into repairing it, because it would cost more to repair than to replace.
Jun 16, 2011 | Magic Chef MCBR440 Compact Refrigerator
Turn thermostat on, cooling fans kick in, i can feel compressor with my hand moving but no cooling inside freezer or fridg
Hi, you say the fan in the freezer kicks on? You also have a fan located by your compressor and coil which is the condenser fan motor and condenser coil. This fan must also be running when the compressor is on.Make sure that the coil down below is clean on the front of it as it draws air across this coil to keep the internal head pressures down. Check all of these things. The small copper line coming off the compressor, discharge line should be almost hot. The larger of the lines is the suction line and will be very cool, almost condensating . If not, you may have developed a small freon leak which will cause these problems. Make sure that everything I said is working and clean, and if the small motor in the rear bottom is not running, you can get a new one at a appliance parts house and 2 wires will replace it. Do all of this and keep me posted.
Shastalaker7
Jun 15, 2010 | Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Side by side whirlpool refrigerator with easy water and ice, not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
Danby DWC044BLP Wine Cooler Logo
47 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
