Question about Dometic Refrigerators
Where is the thermistor located
Just want to know where it is located
    Top Expert:
  • Dometic Master
  • 8,163 Answers
Back on bottom remove cover to board and disconnect big plug
Posted on May 27, 2016
I have a samsung dv337aeg/xaa dryer that does not heat
could be thermistor but also may want to check the heating element, the hi-lo limit thermostat, and see if u are getting full power to the unit as if only getting 120 instead of 240 u have enough to run the motor but not the heater? thermistor located in the housing near the blower, sometimes in the drum or on the door
Jul 27, 2014 | Samsung Dryers
Thermostat thermistor
The thermostat is usually located on the front of the burner chamber alongside the flame sensor. It is not a water thermostat but a type of thermocouple that let's other components of the heater know the unit has fired
Jan 15, 2014 | Water Heaters
Wd 52631 thermistor part number?
Are you looking for one in the power supply? All these parts have a location number on the board where they are located---should be easy to Google the location and model number to get what you want.
Mar 21, 2012 | Mitsubishi WD-52631 52" Projection HDTV
Cycle stops at water heating. Water gets too hot and cycle can only be moved on manually. Is this indicative of a faulty thermostat? Where is the thermostat located
Sounds like it.
It is actually called a thermistor, and is located at the end of the heater element.
Which in turn is located at the rear of the washer drum.To gain access, remove lower rear cover of washer, and you will see the element and thermistor there.
To remove the thermistor, slacken the centrt nut securing element, and withdraw the thermistor.
Fit new thermistor, tighten up nut, and that is it.
If problem persists, then it is going to be a faulty pcb.
Feb 13, 2011 | Hotpoint WMA13 Front Load Washer
Dryer shuts off after 5min (code E1)
Well the error E1 message indicates that the thermistor is defective and needs to be replaced.
Try unplugging the unit for a few minutes got rid of the error, but lately the temperature just hasn't been hot enough so the clothes don't dry. You must need to replace the thermistor for full working of your dryer. you may please follow the below steps to know how to change the thermistor -
1. Locate the thermistor on the top right hand side of your dryer. This will be a small platelet with a chip and wires coming out of it. Use your screwdriver to remove the two screws holding the thermistor on the unit.
2. Unplug the wires from the thermistor.
3. Plug the wires into your new thermistor. Replace the thermistor on the dryer and the screws holding it in place.
4. Replace the back panel of the dryer and plug your dryer back into the wall outlet.
5. Push your dryer back up against the wall and turn it on again.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE3 dryer keeps stopping indicating an E1 error. The model number is 110C82822100
Post comments for further help or information......
Good Luck!!
Aug 28, 2010 | Kenmore Dryers
My GEW9200LW0 electric dryer will stop after a few minutes and flash E1 code. Is it most likely a faulty thermistor? How do I know the correct part # to order?
HI, the thermistor is the culprit in this situation. the actual location of the affected part is inside the unit, on the blower housing(mounted on the backside). The part number is (3976615)
E-1:=(Failed Thermistor)
SIDE NOTE:-The manufacturer has replaced part number 3976615 with this item, part number 8577274. 8577274 may differ in appearance, but is a functional equivalent to prior parts including 3976615.
Oct 21, 2009 | Whirlpool Dryers
Trying to locate thermistor whirpool dryer and replace it
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180470.pdf
Try this web site. Look on page 5, item 42. It is listed as a thermistor. If you can not get to the site, let me know and I'll give you the step to find it on the whirlpool web site.
Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
Samsung washing machine error TE appears part way through wash. Does not appear to be temperature related as it's nearer the end of cycle? Do you know what this error relates to?
thermistor error, so actually it is temperature related. the thermistor is located at the bottom of the tub asm. with the heater element. check wires and replace thermistor. the tech paper in the washer may give the proper ohms to check it with a meter.
May 27, 2008 | Samsung Washing Machines
Thermistor Location on Ricoh CL4000DN
Thermisters are located in the fuser unit. They contact the rollers. Good luck
Apr 03, 2008 | Ricoh CL4000DN Laser Printer
Refrigerators Logo
27 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
