Question about Ariston Technologies AW 129 NA Washer With 1200 rpm max and 16 lbs/7.5 kg. Load Capacity (AW129NA, AW129 NA, AW-1...
Error code h20
What does it mean
    Master:
  • Ariston Tech... Master
  • 480 Answers
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Posted on Oct 06, 2015
Ariston codesH20
H2O means the applionce isnt getting enough water check the waste hose is not pushed to far down the upstanding ( should be in no more than 4" )
Mar 11, 2014 | Ovens
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
It keeps coming up h20 on lcd screen
(Quote)
Error code H20
If your machine IS in demo mode come back to me and I will tell you how to get back to normal mode - it's too long to put in this solution ;-0)
John C.
Apr 25, 2011 | Hotpoint Ultima WF865 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Dec 24, 2009 | Washing Machines
H20 ERROR
This error means - Problem is in the inlet valve.
Your inlet valve at behind top of machine is defective or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem then you need to change inlet valve.
Good Luck!!
Thanks
Jul 24, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
163 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
