Question about Salton Kitchen Appliances - Others
Need a replacement cover
How can I order one?
How do I replace the SD cover on a nikon D60
HiIt it is very easy. but you need guide how to remove. If you can get sd cover, I will let you know within skype. the part will be about $5. You can order directly from nikonusa part order deck.
May 26, 2011 | Cameras
Does the valve cover on a 2002 Altima 2.5L have to be replace if the spark plug seals are bad
No you do not have to replace the valve cover, you however to need to replace the spark plug ring seals. You can find it on ebay, or go to your local auto store, like autozone, advance auto, and they should be able to order it for you too. You may need to take out your valve cover in order to get to the spark plug rubber seals which is on the inner side of your valve cover.
Feb 06, 2011 | 2002 Nissan Altima
How do i replace a valve cover gasket? How do i take the screws off the valve cover gasket? Do i need a special tool? I just ordered a new valve cover gasket and i need to know how to replace it..please...
First take the plastic cover and carefully loss out the bolts and take every one of them and replace the new gasket and place the bolts back , it is as easy 1234
Aug 24, 2010 | 2002 Volkswagen Passat
Need the battery cover for Pinseeker 1500, live in Tampa, Florida or am willing to order it on line. Need the cover by July 9th
Call them Monday!!!! Tell them the situation. They can mail you a replacement battery cover the same day. It might get there by the 9th. You can overnight it.....for extra bucks. 800.423.3537
Order more than one!!!!
Mr. Tech Geek
don't get to vote/rate!!
Jul 04, 2009 | Bushnell PinSeeker 1500 20-5103...
Installing klutch
Buy clutch cover gasket
Unhook clutch cable at clutch cover
Remove clutch cover
Remove 5 clutch spring bolts
Remove springs
Remove pressure plate
Remove plates and disc noticing order
Replace with new plates/disc in same order (after soaking in oil for at least a few hours, over night would be better.
Put everthing back together in order of removal.
May 03, 2009 | 1997 kawasaki VN 800 A Vulcan
Canon PC20 exposure lamp replacement
Back cover,left cover,and top cover.In that order.(Left cover opens with 2 clips.)Remove the glass.And then you can replace the Lamp.
Oct 31, 2008 | Office Equipment & Supplies
How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Apr 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
I need to replace frydaddy cover
For a replacement cover call Presto customer service at 800-877-0441. Have the complete model number found on the bottem of the unit.
I starts with 054xxxx. Orders are taken with credit cards.
Feb 18, 2008 | Presto 05420 FryDaddy Deep Fryer
Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
Feb 16, 2008 | Microwave Ovens
Kitchen Appliances - Others Logo
26 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
