Question about GE X500 Digital Camera
Reset my GE X500 to take 640X460 photos
I have to resize every photo I take
How can I resize pics for printing for my desktop?
Here's a great link that addresses the issue and also suggests what software to use: How to Resize a Photo for Printing
http://www.ehow.com/how_4442570_resize-photo-printing.html
Aug 02, 2012 | Lexmark Impact S305 Wireless All-in-One...
Why are my pictures blurry on my 8ff2fpb 37
I had the same problem with my photo frame but was happy to find the answer to the problem on the website for my photo frame:
You need a resizing program to resize all your photos to the recommended size for your frame. The program I used is:
http://www.faststone.org/
and here is the step-by-step instructions on how to resize all the pictures at once:
https://nix.zendesk.com/entries/22222492-How-to-Re-Size-Photos-for-your-Digital-Frame
After that all the pictures, even the ones with lower quality displayed perfectly fine on the photo-frame.
Apr 24, 2012 | Cameras
Panu pu ba idet ng pic sa photoscape
To resize your photos, click, click on the Editor button. Then select the folder where is the photo located. You can select more than one photo. Drag and drop the photo to the empty box on the right. Then select options, click the resize button and select the length or width. Then click the save button and you're done!
To edit multiple photos, go back to the main menu and click on the Batch Editor Button. Then select and drop your photos to the right, select the resize measurements and click convert all button. The originals get automatically saved in another folder, and the resized photos are saved in a folder that you select.
You can also combine multiple photos in one and make a collage. It's pretty cool feature to use. You can use other editing features to enhance your photos- you can crop your photos, add text box, add different shapes, rotate your photos, remove red eye, you can brighten or darken your photos, increase saturation and color or decolorize in sepia or in black and white. You can sharpen them, use contrast, bloom or backlight and you can add different filters to change your photos in cool ways.
There are a lot of things that this program allows you to do with your photos so you can customize and enhance them before printing, emailing or publishing them on the Internet. So, have fun editing and resizing your favorite photos and share them on the Internet with all your friends and family!
Mar 22, 2011 | Philips GOGEAR SA6045 MP3 Player
When I try to send a photo with a text message I get 'message sized reached maximun limit' have set at 1M
Open photo and then go to menu. Go to more items and then crop the photo. You have to resize the photo and then save it. Send the message again with the resized photo and it should work.
Dec 02, 2010 | HTC Hero Smartphone
How do you burn a dvd? I clicked burn to dvd but it's not working
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can have problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that everyone were under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. Also, you could be using the wrong type of disc. Try DVD+R.
Jul 24, 2010 | Individual SlideShow Expressions
I receive "failure writing to disc" message as I try to burn slideshow to dvd within the program
SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (However, I've burned projects containing up to 388 successfully; photos at original size.) This can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. I've been using DVD+R.
11407336
May 20, 2010 | Individual SlideShow Expressions
After trying for over 12 hours, we can't burn the slideshow to a dvd. What are your suggestions?
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. I've been using DVD+R.
11407336
May 15, 2010 | Individual SlideShow Expressions
Can;t get the software to write the slide show to a DVD
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. Try DVD+R.
11407336
Feb 26, 2010 | Individual SlideShow Expressions
Brookstone my life pocket album error
I had the same problem. I lwas able to load more pictures because I bypassed the function. It is easy. Just open the resized picture file on your computer, then, copy (control c) the pictures you want, and then open the photo album device through "my computer" and paste into the appropriate album. My digital photo album was listed as F Drive in my computer.
Feb 06, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
GE X500 Digital Camera Logo
52 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
