Question about Supersonic 7" Munchkinz Tablet Pink
Hard reset from power up
Needs restored
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
Cmp 741e I have a tablet that I got out of a storage locker. Is there an way to unlock and reset the password
Either try default factory reset or what is referred to as hard reset by holding/pressing both the 1. Volume up key/button and the power button/key (simultaneously) Or 2. Volume down key/button and the power button/key together.
Then follow the restore prompts
If unable to JumpStart the restore process this way, you may have to FLASH the stock ROM firmware then
Oct 09, 2017 | Tablets & eReaders
Where can I sent this Kocaso tablets back for something works this is the most usuless peace of sh.. That was ever sent to me. It won't stay on a minute and then returns to the logo page and you try
Try hard reset: With the power off, try holding down the up volume button and the power power button. After it starts up with something appearing on the screen then release and this may get you to the factory restore option menu.
How do you factory restore Kocaso Android tablet through hard reset...
May 22, 2015 | Tablets & eReaders
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How do I do a hard reset on a tablet samsung
for soing a hard reset you need to do te following things:-
1. go to settings
2. open backup and reset
3. click on "restore to factory settings" option.
your phone is hard resetted now/. enjoy
Oct 04, 2014 | Samsung Tab Tablets & eReaders
How do you reset a ipad 2 when the screen won't turn on?
You can try to do a hard reset or a factory restore.
To try a hard reset, hold the home and power button down until the device turns off and the Apple logo appears on the screen.
To do a factory restore, connect your iPad to a computer with iTunes. Once connected, open iTunes and then click the factory restore button on the device settings.
Hope that helps!
May 02, 2014 | Tablets & eReaders
Unfreeze ipad
hard reset, press power button on top and front button at the same time till it shuts down, 5-10 seconds, then turn on normally, if not fixed, hard reset, and do a restore from iTunes and your computer
Jan 13, 2014 | Apple iPad Tablets & eReaders
I HAVE A TBS "T-PAD" THAT I NEED "DETAILED" INSTRUCTIONS ON HOW TO FACTORY RESET OR HARD RESET. I HAVE NO MONEY TO TAKE IT TO A REPAIR SHOP , HELP ME!!!
you should be able to go into you settings and find the factory reset there and before reseting it check to see if there is a back up and restore box if there is click it so when you turn the tablet back on you should be able to restore all of your apps and music content back.
Nov 11, 2013 | Tablets & eReaders
Reset and delete all info
First, power off the device. then, press the volume down and power button together, this will cause a "hard reset" for the device, then using volume up/down button select "wipe data/factory reset" using the power button to confirm. This will erase all the data on the device and restore back to all factory settings
Feb 08, 2013 | Nextbook Premium 8 Se Android
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
Dec 08, 2011 | HTC HD Windows Phone 7
Supersonic 7" Munchkinz Tablet Pink Logo
55 people viewed this question
Top Supersonic Tablets & eReaders Experts
Paul Bade
alibaba69
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
