Question about Ricoh Aficio Mp C6000 - 464k Copies - Feed/fax/finisher/bank/print/scan
Need to remove staple finisher from a ricoh MPC6000
Cp6000
4 Suggested Answers
  • 114 Answers
SOURCE: I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Posted on Mar 17, 2010
  • 1833 Answers
SOURCE: I have a Ricoh Aficio 551 copier with the Booklet
According to your problem.
Don't keep any pin or metallic things inside it.
Adjust your paper size properly.
Don't use wet & damp paper.
keep the paper properly on the paper try.
you can follow the mannual of the printer.
Posted on Jan 05, 2011
  • 367 Answers
SOURCE: I have a Ricoh 551 Copier with the Booklet
I was able to locate a service manual that should help you. It has sections for the folding mechanizm and how to adjust it. I would write it all out here for you, but sometimes pictures are better then words and this service manual has both. The manual is not Ricoh 551 specific, but it is compatible with the unit so the instructions should be the same.
http://www.download-service-manuals.com/download.php?file=Ricoh-1903.pdf&SID=qjp21rph66d0tbsukcfvbn2fccofefr5
Regards,
Chris
Posted on Aug 29, 2011
Paper always jams even without starting,,,,specially when im going to print cardstock, it never works
Jams from where? Need more info. Cardstock must be printed from the Bypass Tray ONLY. Make sure you select the proper paper type from the Printer Properties tab in the driver.
Oct 13, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
I have ricoh mpc6000 there is error code 300 how to solve
SC300 D Drum charge corona wire error: K
The output of the charge corona wire of the black PCU is abnormal. • CGB power pack connection loose, broken defective
• Check CGB power pack connection to BCU
• CGB power pack defective
• BCU defective
• Replace OPC drum More likely needs a new Charge assy. or Charge grid. Roughly $20-$100 for part(s).
Apr 29, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Ricoh mpc 6000 sc540 error code
my reecho mpc6000 calur macing problem yellow toner add , pl help
Jan 31, 2013 | Ricoh Aficio Office Equipment & Supplies
Jan 20, 2010 | Ricoh Aficio 1035 Copier
I need to change staples
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
Will not staple
Hello sir; Remove the staple cartridge check there have left over used staplers , just dump it out,also need to check vertical lifting motor moving smoothly.
Jun 01, 2009 | Ricoh Aficio 450 Copier
I have a Ricoh Aficio and I cannot find how to use the stapling feature.
Are you sure it has stapling?
Some machine may show it on the control panel but it is an option that may or may not be installed.
Is there a stapler in the sorter?
If it does, then the stapling should come up as a finishing option when making copies.
On your control panel, there will be a Sort, Group and a Sort/Staple option.
Select this feature and it should staple your copies.
If you select this and it doesn't staple then it may be out of staples or the copy is not the correct size or orientation to allow stapling.
Apr 15, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 450 copier
Wrench means "call for service" More information may help Ed
Jun 14, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio Mp C6000 - 464k Copies - Feed/fax/finisher/bank/print/scan Logo
16 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
