Question about Imperial IFS40 Deep Fryer
Black soot slowly builds black soot
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Soot is caused by a few things in gas appliances. Propane even more so. Lack of combustion air is usually the culprit. In propane fired equipment orifice alignment, high pressure or the wrong burner orifice can cause yellow flames the result in soot build up. You need to find the culprit. Best to have a service tech check it out and clean it. when you know what to look for it can be easily fixed.
Posted on May 15, 2014
Soot coming out of flu
Hi there.
Soot coming out of the flue indicates poor flame quality and probably carbon or soot build up on fire tubes.
Have a technician check the gas pressure and the fire tubes for verification and cleaning if needed.
Regards.
Sep 23, 2013 | Pitco Frialator 35CS Deep Fryer
How to remove erg valve jammed in the inlet manifold on Renault Espace 1.9dci 2005
The EGR is a tight fit in the manifold when new and clean. Add 1000's of miles of carbon/soot build up on it and there is your problem. A couple of solutions, (a) normally, working it by turning and moving it fore and back, bit by bit it will come out. (b) a good dose of a cleaner such as Wynn Diesel Power 3 (this contains an additive that lowers the burning temp of soot) and a long, high engine speed trip will remove a good bit of the soot build up, then back to plan (a) Slowly, slowly, catch the monkey..... It's frustrating, but it will come out, eventually!
Sep 13, 2013 | Cars & Trucks
My fryer burns with alot of black soot
you need to clean the burners and the fire tubes, remove all carbon deposits.running the unit on low gas pressure results in carbon build up on burners and fire tubes.
Mar 11, 2011 | Pitco Frialator Kitchen Appliances -...
Black soot comes from tailpipe when hard acceleration.
normal carbon build up run some stp gas treatment
Oct 14, 2010 | 1996 Chevrolet Impala SS
What causes soot build up in burner chamber
Sounds like you're not getting enough combustion air.
If you have a draft motor or blower make sure it is running.
Apr 30, 2010 | Fasco Bradford White Hot Water Heater...
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Teledyne Laars EPC-400 lights about 2% of the time I turn it on.
You may want to pull your pilot assembly out and clean it. If you have one. Some of these had a problem with soot building up on the pilot and that would cause the ignition spark to flow threw the soot ball that would build and you would hear a buzz rather than a spark. So no spark no ignition. After it tries a number of times the soot will move enough to let it light, but will build more soot and make it worse for the next time. If this is the problem this will reoccur and you can just set yourself to clean it now and again or the replacement has been improved to allow mor air to keep it from sooting. I hope this helps, good luck.
Dec 28, 2009 | Teledyne Laars Pool & Spa
1999 Fatboy backfiring & no spark
The guy with the same problem..Your leaving your enrichner (choke) out thats where the 2000rpm and soot comes from...Original fellow I think you may have an intake leak around your manifold or carb.
Apr 21, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Will soot ( carbon) from fire effectthe devices
The carbon build up may shorten the life of your electronic items the best thing to do would be to remove as much as u can using an air spray can, do not use liquids to clean the things unless it isopropyl alcohol in small quantities.
Apr 03, 2009 | Audio Players & Recorders
Imperial IFS40 Deep Fryer Logo
262 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
