Question about Cateye Fitness EC UB200 Cateye Upper Body Ergometer
Need a part number for the power jack and charger
I need to find a source to purchase a 12v DC power supply and the female jack it plugs into.
I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or...
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Dec 10, 2012 | Computers & Internet
Power supply blown
You can check your AC adapter by voltmetter in Dc mode, one probe touches inside the plug, other probe touches outside, it should have dc reading if the ac adapter is working.
Your plug is slightly burnt, indicating that the DC jack is broken or loose.
Most DC jack can be replaced if you know how to solder, it costs only under $5.
http://cgi.ebay.com/DC-Power-Jack-Fu...3286.m20.l1116
I believe your DC jack needed to replace and a repair guy might charge you over $150 to replace a $3 part. You should do it yourself if you have a skill to take a laptop apart.
Car Tuning
May 24, 2012 | Computers & Internet
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Where can I get replacement parts for my D1708ES DVD player. I need a new 12V DC power source adapterand a new AV Adapter cable )one to three Female)
I'm sure Radio Shack can help you out in finding an adequate replacement otherwise there are many online stores that can sell you parts cheaper if you have the part numbers. Just do a simple search on google. Radio shack or any electronics store would probably the easier option. let me know if you need any thing else
my best to you
Aug 05, 2008 | Audiovox D1830 Portable DVD Player with...
Cord missing
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Apr 15, 2008 | kawasaki PVS1965 Portable DVD Player
Cateye Fitness EC UB200 Cateye Upper Body Ergometer Logo
Top Cateye Fitness Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Cateye Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
