Question about Car Audio & Video
I ned to find the PIN code for a Eurovox Cassette Radio Model No 69311 erial no 241002375.1. and which pin is for the continuous power supply. The radio is from my son's Peugeot Mi16. He changed the radio several yaers ago and we do not have the PIN as he is now living overseas. There are two pins which do no have wires attached - both next to eah other and in the centre of the wiring block. All other terminals have wires attached and are labelled.
  • hall_glenn Jun 15, 2009
    Thanks for this Raylee, I will have a look tomorrow. However you have not answered the second part of the question about identifying the termional for the power connction which keeps power on all the time.
    Glenn
    Brigadier General:
  • 8,619 Answers
Hi
Try this code generated from the Radio Code generator-- 531664
The upper code will definetly unlock your radio.
If it isn't unlocking then please tell me if you have still got the original papers that came with the car? Please check the last 3 pages of radio manual for the same. The code consists of 6 digits -- each digit is a number between 1 and 6. Just turn on the radio, then punch in the numbers using the buttons for the preselect stations (1 -6). At the end of the sequence, the radio should switch itself on starting at the base FM band 87.5Mhz.
If you are unable to reset it then follow this old fashioned trick to unlock the radio-- take the radio out and stick it in the freezer for half an hour(not more then half hour). This may reset the unlock security feature.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 15, 2009
  • Rylee Smith
    Rylee Smith Jun 15, 2009
    Generally the color of the +12V wire in Puegot Mi16(power carrying wire) is BLUE. However you'll need to tell me your current car's model so that i can tell you which wire to look for. You can also check this by using a multimeter.
    Thanks
    Rylee
Hello sir I have canon ir 3300 in this code error is 000001-0002 so how can I solve this error
http://printcopy.info/?l=en&mod=erc&brand=canon&model=ir3300&code=E001-0002
Quoting from internet link:
Exploded Views and Parts List Free!
Code
E001-0002
Description
The sub thermistor detects about 295C or higher
Causes
The fixing film unit is faulty (i.e., the thermistor has a short circuit). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service move: COPIER>FUNCTION>CLEAR>ERR.
Remedy
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 W (short circuit)? YES: The thermistor has a short circuit. Replace the fixing film unit. If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC= 250°C for the main thermistor; FIX-E=310°C for the sub thermistor. 2. Main power supply PCB, DC controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Canon iR3300 Error Codes
May 01, 2018 | Canon Office Equipment & Supplies
What is the radio code for mercedes benz radio cassette eurovox model 8790
Try asking your Merc Main Agent. Give them proof of ownership and they can look it up for you. If it is the original radio.
Aug 14, 2014 | Cars & Trucks
How to use eurovox pin in a vx commodore?
Radio P.I.N. (Personal Identification Number)
Your PIN. must be entered if the battery is disconnected. The P.I.N. is shown on the
security card that was originally in the glovebox of the new car. Please keep the card in
a safe but accessible place (not in your car), as this safety feature is provided as a theft
deterrent.
To enter the P.l.N.:
•turn ignition to accessories and turn radio on ("1" or "CdE 1" appears),
•press the radio buttons in your P.I.N. order,
•the radio will shortly begin to play.
If an incorrect P.I.N. is entered the number "2" or "CdE 2" appears on the display.
Following three incorrect P.l.N.s the display shows" - - - ", and the radio must remain
connected to power for approx. one hour before the correct P.I.N. can be entered.
Therefore, if your car repair requires battery disconnection you may wish to provide the
servicing dealer with your PIN.
If the P.I.N. number is XXXX, contact your Holden Dealer. He will require proof of
ownership and the Vehicle Identification Number shown on the inside front cover of this
handbook. There may be a nominal charge for this service.
May 31, 2014 | Blaupunkt PCA250 Car Audio Amplifier
How to reset pin code PIONEER KE-1900 CAR RADIO CASSETTE as I have forgotten it
What pin code? I have never seen a pioneer tape deck that requires a security code.
Jun 20, 2011 | Pioneer KEH-1900 Cassette Player
My son has lost his manual for his car which had the security code for the radio cassette in it. It is a Eurovox model 4115 SN: 359046057.7. Need code after battery replacement!
if it is a stock unit the code is available from the car dealer. you will need id, registration and the serial number off the bottom of the radio.
Dec 23, 2010 | Car Audio & Video
I've lost the pin code for my eurovox radio model No 4685i what can i do??????
You must call the manufacturer directly and probably have to pay a fee. If it is stock radio that came with car phone vehicle manufacturer. Good Luck
Mar 26, 2010 | Car Audio & Video
I have a 2003 suburban.my radio didnt work.i bought anither same model radio from ebay. when i put it on it says locked. need help. how to unlock this radio. thanks
If it is a Eurovox brand you need the pin code. If you dont have the pin code you need the serial number of the unit and you can get the code from a company called Go Technologies via the www.eurovox.com.au webisite. This costs a small fee and the application form can be downloaded from the website.
If it is a Eurovox radio you can enter 1111 if the code is a 4 number pin of 111111 if the code is the 6 number pin. This will put the unit into test operation for about 3 minutes to at least see if the unit works. While in this mode the screen will blink continually.
Sep 11, 2009 | OEM Systems Car Audio & Video
04 tiburon, I have power at the radio and to the amp but no music, put in new amp still no music????????????????????
What features exist with this radio?... CD player, AM/FM w/cassette? When you write 'no music,' do you mean none of the features are working AT ALL? You said you've verified power at the radio. Did you verify this because the visual display comes on (radio station display, CD track, etc)? Does this image/pic look like your radio? If so, there are TWO power inputs to it.
Yellow wire & Red wire (Y=pin 7, R= pin 16). Pin 16 is always HOT (ON), and pin 7 is ONLY HOT when the ignition key is in Accessory or Run position. You also have a connection/circuit to the amplifier - pin 12 (white wire with orange stripe) to pin 8 of M63-2.
Hope this helps. Once you've verified you have good connections (power & grounds -- and no shorts to ground), I'd say the audio head (radio) is defective.
Apr 03, 2009 | 2004 Hyundai Tiburon
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
Car Audio & Video Logo
107 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
