Question about Mattel Fisher-Price Imaginext Big Foot
How do i make the ferocious big cats nature puzzle
9 tiles together so they make up a 3x3 square make sure the head on each edge matches the tail of the adjacenttile
I need to know just how much backsplash to buy for a kitchen wall it is 9 ft 7ins X 1FT 2INS and 3 FT 2 INS X 1 FT. and if I need 2 boxes how would I order it in 1 square feet?
Hi Connie
Did you get that roof fixed? ;>)
You have to round these figures out a bit, and you always needs a few extra tiles in case of breaks or bad cuts.
So your 9ft 7 ins X 1ft 2ins is 10 foot x 1.5 feet is 15 square feet, or 1.66 square yards.
Your 3ft 2 ins x 1 ft is 3 square feet or .33 square yards.
Add the 2 together 1.66 plus .33 and as near as makes no matter, you want 2 square yards. I just had a quick check and wall tiles are packed in Square FEET. You need 18 Square Feet.
box ceramic wall tile Google Search
If you are careful, one box like this will do as it 17 square feet.
https://www.rona.ca/en/ceramic-wall-tile-04775020--1
Description This cream-colored wall ceramic from Bravo has a glossy finish and is made for interior use. One box contains 136 3" x 6" tiles and covers 17 sq. ft.
Get yourself a notched trowel to put the adhesive on.
https://www.tiles4all.co.uk/Tile/Professional-Notched-Trowel---3mm-x-3mm-x-3mm-SKZZTOO795
And a grouting squeegee to spread the grout.
https://www.wickes.co.uk/Wickes-Tile-Grout-Squeegee/p/166161
And one of these to smooth the edge of the grout into the joints.
http://generaltoolstore.com/vitrex-10-2280-grout-finisher-double-ended-easy-tiling-tool-wall-tile-grouting-56670-p.asp
Another consideration is that some tiles are self spacing, but on others you need to use spacers to have a gap between them. Link in this article.
http://howtospecialist.com/indoor/how-to-install-wall-tile/
If you have to cut tiles, tile cutters are expensive, but the big box DIY stores will rent you one.
Feb 11, 2018 | Cars & Trucks
Tip
Solving any jigsaw puzzle no matter how big
Big puzzles can at first seem to be very daunting, but when you complete it you feel a great sense of accomplishment. It doesn't matter if your puzzle is 50 peices or 1000 pieces using the same technique you are able to solve the puzzle no matter how intricate the image may be.
Always start by separating all the pieces according to whether they are edges or not, when you have separated all the pieces take the edges and start putting together your boarder. This helps give you a nice starting point and it gives you an idea of the size of the puzzle.
Once the border is completed if you are working with friends or family you can split up with image inside, like if its a landscape one could do the sky while another does the ground. I find it easiest to pull out all the pieces that go with the area you want to work on and lay them out facing you to see what matches.
After the big parts of the puzzle are completed the smaller things will begin to fall into place and before you know it the puzzle will be finished!
on Oct 27, 2013 | Toys
I'm trying to figure out a 3x3 magic square where the rows equal 21 18 10 and the columns equal 15 24 13 using the numbers 1-9
I don't think you can do it! Could you check your numbers.
If we are using the numbers 1-9 once and only once in a 3x3 magic square, the sum of the rows + the sum of the columns should be 90, since 1+2+3+4+5+6+7+8+9 in the rows adds up to 45 and 1+2+3+4+5+6+7+8+9 in the columns adds up to 45.
When trying to solve, the magic number seem to be the sums 24 and 10. To get 24, the only three numbers that add to 24 are 7 + 8 +9. Similarly to get 10, the lowest numbers re 1 and 2 and the smallest big number to use is 7. I then ran out of number trying to get 21, 13 and 15 sums.
Good luck,
Paul
May 21, 2015 | Office Equipment & Supplies
Does anyone have the solution to beach trails by dan gilbert ?
The problem with this puzzle is in the wording of the constraints. We all assume that every edge has to touch a matching edge, but it does not actually say so in the rules. It can be proven that there is no solution if you require every turtle and crab edge to be matched, since there is an odd number of edges in total for each species.
I also wrote a program to compute the solution and it generated many configurations using 35 tiles with this bogus constraint. The final tile can be placed in the last spot if you allow two of its path edges to touch the non-path edges of surrounding tiles.
https://gist.github.com/adufilie/7da4d16889169add3866dfa42b7f9847
Mar 03, 2012 | Audio Players & Recorders
I want a solution to 19 piece Tile puzzle Lizards
Fairly straightforward. It's where you start. Start with the 5 headed and 1 tail tile in the middle. The rest is just trial and error, about an hour.
Feb 02, 2011 | Puzzle Toys
I can't solve the big sheep puzzle there are only 2 solutions do you know them 16 cards two of which are identical
This same puzzle was copied and handed out at a Mensa meeting according to this link:
http://www.cs.utsa.edu/~wagner/sheep/index.html
I have verified that the Mensa puzzle and the "Big Sheep Puzzle" at www.thebigsheep.co.uk are identical. The spotted sheep are replaced by the brown sheep in the Mensa puzzle. The instructions on the box claim 2 identical tiles, but there are really 2 sets of identical tiles in the puzzle. The author of the link above found 55 distinct solutions.
Jan 01, 2011 | Toys
THIS GAME IS SO HARD I AM STUCK ON PUZZLE 9! HELP ME PLEASEE
here you go
Puzzle #9 -One Poor Pooch
  1. Just keep the basic anatomy of a dog in mind when you're moving around the matches.
  2. The triangle represents the head, the match at the end is the tail, the square is the body, and the four matches at the bottom are legs. The dog must have all of these in the final product.
  3. Don't think of this in real life terms. Think of a cartoon dog getting flattened by a steamroller.
  4. Move the two inside legs to the top half of the square facing outwards.
  5. Reward: 35 Picarats
  6. Hint Coins:
    • Tap the candle directly above Matthew's head.
    • Tap the circular painting underneath the middle of the three paintings by the stairs.
    • Tap the top level of the bookcase.
  7. After collecting the hint coins, tap the bookcase to start up puzzle #10.
Feb 03, 2009 | Nintendo Professor Layton & the Curious...
Puzzle 009, one poor pooch.
keep solving puzzels - it will all come together!
Jan 08, 2009 | Nintendo Professor Layton & the Curious...
Mattel Fisher-Price Imaginext Big Foot Logo
82 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
