Cougar ls9 screen terminal space 2.5
Screen displays Termainal space 2.5 and will not clear
2 Suggested Answers
SOURCE: zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Posted on Aug 03, 2008
99 cougar electrical problems
1) Disconnect your positive terminal (Warning don't allow terminals to
Touch.)
2) Go to fuse box Remove the ECM fuse (leave fuse out for 10 minutes)
3) Put fuse back in its slot, the connect the terminal.
Jun 08, 2012 | 1999 Mercury Cougar
How to change the time
You can find the full manual here:
http://www.obfs.uillinois.edu/common/pages/DisplayFile.aspx?itemId=918000
But here's the part about changing the time:
System Reset-DATE or TIME
To change the terminal Date and/or Time:
1. Press the More function key.
2. Press the green Enter button until the terminal screen displays Other Set Up.
3. Enter the password (last six digits of the Merchant ID# or 998877).
4. Press the Enter button.
5. Press the More function key.
6. Press Enter until the terminal screen displays Date/Time.
7. Press Enter for Date (MMDDYYYY), enter the correct Date, and press Enter. Go directly to Time, and bypass Date, by pressing Enter twice.
8. Press Enter for Time (HHMMSS), enter the correct Time, and press Enter.
9. To Exit, select the red Cancel/Clear button twice.
Mar 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Which terminal of the capacitor does the diode attach to?
Hello
There will be a marking on one end of the diode, which denotes its cathode. On some diodes there will be a ring band on this end. For some otheres there will be an arrow mark folloed by one vertical line. This end denoted the cathode of that diode.
The cathode of the diode should be connected to the positive [+] terminnal of the capacior. Positive terminal of the capacitor will be marked [+}. In most capacitors, negative [--] terminal will be marked with a line on its body. In such capacitors, you can identify the negative, as marked, and can detect the other as positive, and the cathode of the diode must be connected to that terminal. the other end will be negative, and to be connected to body in most elelctronic equipments.
Anyway, the cathode of the diode must be connected to the positve[+] termainal of the capacitor. OK.
Feb 12, 2011 | Vacuums
Why is image on screen is to wide
A wide screen display requires setting the appearance
procedures
1. right click on a space on the desktop without icons
2. select from a list prompt the settings with click should provide link with which to select the appearance setting
3. choose from the display icon prompt after clicking a pixel quality
4. a larger figure chosen from the list should decompress the screen pixels creating clear pictures though adjusted screen to fit the area
Dec 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
What button sequence to I press on the vic to get the cpu codes for the check engine light?
Reading & Clearing Codes READING CODES (EXCEPT CADILLAC) Fig. 4: Example of a code 12 displayed on the check engine lamp 79222g25.gif
Since the inception of electronic engine management systems on General Motors vehicles, there has been a variety of connectors provided to the technician for retrieving Diagnostic Trouble Codes (DTC)s. Additionally, there have been a number of different names given to these connectors over the years; Assembly Line Communication Link (ALCL), Assembly Line Diagnostic Link (ALDL), Data Link Connector (DLC). Actually when the system was initially introduced to the 49 states in 1979, early 1980, there was no connector used at all. On these early vehicles there was a green spade terminal taped to the ECM harness and connected to the diagnostic enable line at the computer. When this terminal was grounded with the key ON, the system would flash any stored diagnostic trouble codes. The introduction of the ALOL was found to be a much more convenient way of retrieving fault codes. This connector was located underneath the instrument panel on most GM vehicles, however on some models it will not be found there. On early Corvettes the ALOL is located underneath the ashtray, it can be found in the glove compartment of some early FWD Oldsmobiles, and between the seats in the Pontiac Fiero. The connector was first introduced as a square connector with four terminals, then progressed to a flat five terminal connector, and finally to what is still used in 1993, a 12 terminal double row connector. To access stored Diagnostic Trouble Codes (DTC) from the square connector, turn the ignition ON and identify the diagnostic enable terminal (usually a white wire with a black tracer) and ground it. The flat five terminal connector is identified from left to right as A, B, C, D, and E. There is a space between terminal D and E which permits a spade to be inserted for the purposes of diagnostics when the ignition key is ON. On this connector terminal D is the diagnostic enable line, and E is a ground. The 12 terminal double row connector has been continually expanded through the years as vehicles acquired more on-board electronic systems such as Anti-lock Brakes. Despite this the terminals used for engine code retrieval have remained the same. The 12 terminal connector is identified from right-to-left on the top row A-F, and on the bottom row from left-to-right, G-L. To access engine codes turn the ignition ON and insert a jumper between terminals A and B. Terminal A is a ground, and terminal B is the diagnostic request line. Stored trouble codes can be read through the flashing of the Check Engine Light or on later vehicles the Service Engine Soon lamp. Trouble codes are identified by the timed flash of the indicator light. When diagnostics are first entered the light will flash once, pause; then two quick flashes. This reads as DTC 12 which indicates that the diagnostic system is working. This code will flash indefinitely if there are no stored trouble codes. If codes are stored in memory, Code 12 will flash three times before the next code appears. Codes are displayed in the next highest numerical sequence. For example, Code 13 would be displayed next if it was stored in memory and would read as follow: flash, pause, flash, flash, flash, long pause, repeat twice. This sequence will continue until all codes have been displayed, and then start all over again with Code 12. CLEARING CODES (EXCEPT CADILLAC) Except Riviera, Toronado and Trofeo: To clear any Diagnostic Trouble Codes (DTC's) from the PCM memory, either to determine if the malfunction will occur again or because repair has been completed, power feed must be disconnected for at least 30 seconds. Depending on how the vehicle is equipped, the system power feed can be disconnected at the positive battery terminal pigtail, the inline fuse holder that originates at the positive connection at the battery, or the ECM/PCM fuse in the fuse block. The negative battery terminal may be disconnected but other on-board memory data such as preset radio tuning will also be lost. To prevent system damage, the ignition switch must be in the OFF position when disconnecting or reconnecting power. When using a Diagnostic Computer such as Tech 1, or equivalent scan tool to read the diagnostic trouble codes, clearing the codes is done in the same manner. On some systems, OTC's may be cleared through the Tech 1, or equivalent scan tool. On Riviera, Toronado and Trofeo, clearing codes is part of the dashboard display menu or diagnostic routine. Because of the amount of electronic equipment on these vehicles, clearing codes by disconnecting the battery is not recommended. Riviera, Toronado and Trofeo (Non-CRT/DID Vehicles) — Using The On-Board Diagnostic Display System: First turn the ignition to theON position. On Riviera depress the OFF and TEMP buttons on the ECCP at the same time and hold until all display segments light. This is known as the Segment Check. On Toronado and Trofeo follow the same procedure, however, depress the OFF and WARMER buttons on the ECOP instead. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. For example, 'EC?' would be displayed on Riviera for EOM testing, while on Toronado and Trofeo the message 'ECM?' will appear. The message is more clear on these vehicles due to increased character space in the IPO display area.
  1. Depress the 'FAN UP' button on the ECCP until the message 'DATA EC?' appears on the display for Riviera, or 'ECM DATA?' is displayed on Toronado and Trofeo.
  2. Depress the 'FAN DOWN' button on the ECCP until the message 'CLR E CODE' appears on the display for Riviera, or 'ECM CLEAR CODES?' is displayed on Toronado and Trofeo.
  3. Depressing the 'FAN UP' button on the ECCP will result in the message 'E CODE CLR' or 'E NOT CLR' on Riviera, 'EOM CODES CLEAR' or 'ECM CODES NOT CLEAR' on Toronado and Trofeo. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset. Toronado and Trofeo (CRT/DID Equipped) — Using The On-Board Diagnostic Display System: First turn the ignition switch to theON position. Depress the 'OFF' hard key and 'WARM' soft key on the CRT/DID at the same time and hold until all display segments light. This is the 'Segment Check.' During diagnostic operation, all information will be displayed on the Driver Information Center (DIC) located in the Instrument Panel Cluster (IPC). Because of the limited space available single letter identifiers are often used for each of the major computer systems. These are: E for ECM, B for 6CM, I for IPC and R for SIR. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. This will be displayed as 'ECM?'.
  4. Depress the 'YES' soft key until the display reads 'ECM DATA?'.
  5. Depress the 'NO' soft key until the display reads 'ECM CLEAR CODES?'.
  6. Depressing the 'YES' soft key will result in either the message 'ECM CODES CLEAR' or 'ECM CODES NOT CLEAR' being displayed, indicating whether or not the codes were successfully cleared. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset.
Jul 10, 2010 | 1992 Oldsmobile Toronado
My screen shows 4 desktops at the same time. If I reset the PRAM it goes to 1 desktop, until it boots to the desktop and then it goes back to 4. See a shot here:...
That looks like Spaces is at work here.
It allows you to have more than one terminal so you can organize and distribute your desktop. I use at least 8 Spaces terminal windows myself.
To disable spaces here is what you need to do:
*Click on Apple menu icon located in upper left corner of your screen and select System Preferences.
* From within System Preferences, Chose Expose and Spaces. Your view will automatically default to the Spaces side.
* On the left side of this window, you will see a check box entitled "Enable Spaces" - just uncheck that box
and that should prevent Spaces from appearing when you boot up again.
* Also, click the Show All button and go to Accounts.
• Click the "Login items" tab to make sure Spaces is not one of the login items as well.
You should have no further issues with Spaces disabled.
**To learn all about how to work with Spaces, here is a great link from Apple:
Mac 101: Using Spaces to organize windows and applications
Regards,
-Mactechtrainer
Oct 06, 2009 | Apple MacBook Pro Laptop Computer with...
Change screen saver picture
The QT-6100 screen saver is the same as the QT-6000. Allocate the screen logo in Scanning System. Create a bitmap image that is 800x600 and send it to the QT using CV-31. Flag clear the terminal and set the option in Display Control to show the logo at clerk sign off.
www.casiohelp.com
May 11, 2009 | Casio QT 6000 Point of Sale Terminal
Tranz380 No Space Error
According to my B of A tech support people, your terminal is running out of memory. Call your tech support and let them walk you through it. You may need to wipe the memory of the terminal and then re-load the application.
After you print a detail report, you'll have to delete the batch and then re-enter each transaction manually and then transmit that batch. This has happened to me twice and they say it's probably due to the age of the terminal (30 yrs in my case).
Do not be discouraged by a tech-support person that doesn't know what to do. Have them ask their supervisor. The last time this happened, I had to call back and get a different tech and even then, she had to pass me off to a more senior tech, who then had to consult someone else!
Keep smiling, it's only a SMALL problem.
Nov 14, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
Zanussi ls9
write to me if you need the manual.as for the soap the dishwasher uses only liquid professional soap and you must connect it inside the tank . there is also a blue pipe for the rinse aid detergent
let me know if you need anything else
Mar 21, 2008 | Zanussi 29 in. LS14 Free-standing...
Zanussi ls9 dishwasher
Jun 10, 2007 | Zanussi 29 in. LS14 Free-standing...
26 people viewed this question
jasbo
jasbo
